Last edit by: IB Advertising
Browse all: 4WD
- Dodge Ram 2nd Gen How to Replace Transfer Case and Seal
Step by step instructions for the do-it-yourself repairs.
Browse all: 4WD
Vacuum Shift Actuator
what else might this be called. I need to replace mine, but apparently there were nobody but idiots at the parts store tonight. Any ideas? Even the Haynes manual calls it Vacuum Shift Actuator...
actuator or shift motor.
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
rockauto and others have them. not sure about autozone or advance. they should, its a common part.
often times the old one just needs to be cleaned up and the rust shaft unstuck,
Leaking what? Gear oil or vacuum ? I think you are being a little vague. Let us know the problem in it's entirety. This way we can help better, and if someone does a search and come's across this thread, they will know whether or not they have the same problem. And pics are always a plus.
If the actuator still works, just replace the o-ring seals. The actuators are like 90 bucks plus... O-rings are dirt cheap.
Trending Topics
Is the gear oil coming from inbetween the axle and housing or is it dripping from the circular diaphram? If its the first then your cad gasket is leaking and those only cost a couple bucks, if its the second then your o-rings are probably dry rotting and those are like 5 for $.25
So I went next door to napa and had the part installed an hour later!
