Coolant Leak...New Location
Old Feb 21, 2012 | 07:07 PM
  #41
For the harmonic balancer. You can rent one from the parts store.
Old Feb 21, 2012 | 07:18 PM
  #42
stewie01's Avatar
stewie01
I'm not sure what year it changed, or if it did, but I had to hunt a "claw" style puller for my '01. We usually get by with a steering wheel puller but, it wouldn't work.
Old Feb 21, 2012 | 07:40 PM
  #43
pulleyman123's Avatar
pulleyman123
So that is affirmative that I do need a special tool. Is this claw style puller vehicle specific? I don't have a nearbye auto parts store to borrow it from so I will have to order it online. Any other tools I will need? besides for your basics?
Old Feb 21, 2012 | 07:41 PM
  #44
any three jaw puller should do the trick.
Old Feb 21, 2012 | 07:43 PM
  #45
stewie01's Avatar
stewie01
That's the name I was getting at....... Also, you don't need a BIG one. A small one will work much better as room will be tight. (We borrowed one from one of our neighbor's and at first all we found was a HUGE one I'm guessing for diesel engine's.) We first called AutoZone and they didn't have a clue what I was talking about.....
Old Feb 21, 2012 | 07:56 PM
  #46
pulleyman123
Would this do the job?
http://www.amazon.com/Sunex-3906-Cap.../dp/B000ROFZ0O
Old Feb 21, 2012 | 08:37 PM
  #47
stewie01's Avatar
stewie01
Originally Posted by pulleyman123
Should be exactly what you need.
Old Feb 21, 2012 | 09:55 PM
  #48
gdstock's Avatar
gdstock
This would be better:
Pulling from the outside edge can pull balancer apart.
Old Feb 21, 2012 | 11:01 PM
  #49
dhvaughan's Avatar
dhvaughan
DO NOT PULL ON THE OUTSIDE RING OF THE BALANCER - it will ruin it... i did this one time on a junk motor just to prove a point and it pulled the outer ring right off.
pull only on the inner portion using a duck foot style, or if the balancer will support it - a 3 jaw hooked on the INSIDE, not on the outside.
on the duck foot style, AKA steering wheel puller - don't allow the pointy shaft of the puller to damage the threads in the end of the crankshaft. thread in the crank bolt to protect the threads and push on the bolt head.
Old Feb 22, 2012 | 05:53 AM
  #50
stewie01's Avatar
stewie01
I failed to mention that you use the claw puller on the inside as dhvaughan stated.
Your balancer will either have thread holes or slots. Thread holes means you can use a steering wheel puller, slots means you use the 3 jaw puller
