Custom Steering Wheel for a 98 RAM
Old Feb 18, 2012 | 06:45 AM
stewie01's Avatar
stewie01
Originally Posted by kejobe
My 2001 doesnt have cruise. I'd have to lay a brick on the petal.
Mine does! And.....It works!
Old Feb 18, 2012 | 08:29 AM
kejobe's Avatar
kejobe
So would the brick!! Thing is, I dont have the ***** to use it.
Old Feb 18, 2012 | 09:21 AM
Hans_GZP's Avatar
Hans_GZP
I put a dodge stealth steering wheel on my 96 ram. I never got around to wiring in the cruise control, but it could be done. I have the stealth air bag wired in (plugged right into the stock harness). I have to cut the center hub off of the ram and weld it to the stealth wheel so the splines were the same.
Old Feb 18, 2012 | 09:24 AM
Hans_GZP's Avatar
Hans_GZP
Old Feb 19, 2012 | 03:51 AM
Thefiremon's Avatar
Thefiremon
well in theory if you went back with a custom steering column with the same splines as factory then all you would have to do is mount everything back up with clock spring in place and you would be good to go. There are several different companies out there that do custom steering wheels for airbags
Edit: misread the post thought it said custom steering column.
Old Feb 22, 2012 | 10:24 AM
wermbang's Avatar
wermbang
I have seen a 3rd gen wheel
Old Feb 22, 2012 | 11:12 AM
I like that..... wonder if the controls for cruise and such actually work....
Old Feb 22, 2012 | 11:31 AM
gdstock's Avatar
gdstock
Way too much yeller' in that cab! But it does stand out!
Old Feb 22, 2012 | 11:39 AM
wermbang's Avatar
wermbang
His cruise didn't work before hand and thinks its vacuum problem. air bag plugged in. had to some some grinding to make something easier to mount (forgot what part, but its with the air bag.) on the steering column
He is changing to black, carbon fiber, and yellow
Old Feb 22, 2012 | 05:16 PM
sniper dave's Avatar
sniper dave
I like the skull. Where can I find one? Does it effect your overdrive button?
