Custom Steering Wheel for a 98 RAM
Old Feb 22, 2012 | 05:20 PM
  #21
Augiedoggy's Avatar
Augiedoggy
Originally Posted by sniper dave
I like the skull. Where can I find one? Does it effect your overdrive button?
us 97 and older ram owners have the OD button on the dash... (and usually a dash without cracks )
Old Feb 22, 2012 | 05:21 PM
  #22
stewie01's Avatar
stewie01
Originally Posted by kejobe
So would the brick!! Thing is, I dont have the ***** to use it.
I wouldn't either. Thing is it's hard to know how well the brake pedal will work with a brick on the accelerator.
Need a helmet and a good stretch of empty road to test..... And possibly a change of pants......
Old Feb 22, 2012 | 05:55 PM
  #23
sniper dave's Avatar
sniper dave
Why they didn't leave it alone is beyond me....
I'm guessing they don't make a "custom" handle that has OD button on end...
Old Feb 22, 2012 | 07:40 PM
  #24
Overdrive button is just a momentary switch, that suggests to the PCM that you don't want to use overdrive on this drive cycle. (unless you push the button again.) You could put a small switch for it anywhere ya want.
Old Feb 22, 2012 | 10:16 PM
  #25
Augiedoggy's Avatar
Augiedoggy
I thought that too...I wonder how it is the diy to reverse the od switch status on startup works then?
Old Feb 22, 2012 | 11:22 PM
  #26
Trips a relay that controls the button circuit when you turn the key to start. Gives the PCM the signal it's looking for for the O/D switch, and turns it off.
