Harland Sharp 1.7 RR's
Old Feb 20, 2012 | 02:48 PM
merc225hp's Avatar
merc225hp
I don't think that is the price for a complete kit, way to cheap. The guild plates are for adjustable rocker's only.
This is what Mopar's adjustable roller rockers kit looks like, you can see the guild plates and the studs for mounting the rockers on.
Old Feb 20, 2012 | 02:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.southeastrt.com/ Ask for John Mercedes.
Old Feb 20, 2012 | 03:30 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
http://www.summitracing.com/parts/CSP-S70037/
-$349.95 + 12.95 shipping = 362.90 lol
http://www.ebay.com/itm/Harland-Shar...item5648a3a6c6
$362.90 - Free Shipping
http://www.harlandsharp.com/dodge_viper.htm
$374 - Plus shipping
http://www.jegs.com/i/Harland%20Shar...0002/-1?CT=999
#351.99 + 13.99 shipping
http://www.southeastrt.com John Mercedes:
Cost of the 1.6 or 1.7 HS non adjustable rockers for the $315 + $15 ship ($330 shipped total) in the U.S. using check
For credit cards use www.paypal.com and add their service charge. Send total $330 shipped in the U.S. plus the $11 paypal charge for a total of $341
On a side note from HS website:
Special Notes: non-Adjustable
* Harland Sharp original series, pedestal mount, Dodge 5.2/5.9 Magnum V8, roller rockers are designed to be a replacement for the factory rocker that fits under the stock valve cover.
* Simply remove the factory rockers and rocker stands and replace with your new Harland Sharp roller rockers. We recommend always checking for head & valve cover clearance and proper lifter preload.
* The non-adjustable rockers are designed to the factory specs. If you change camshafts or machine the heads, you will have to correct your pushrod length. Always check before installing. We recommend them only to be used for serious racing applications.
Old Feb 21, 2012 | 12:15 PM
TheycallmeLaramie
Since my motor is like 210,000 miles do you guys suggest replacing the pushrods, and springs?? The motor is running great so I don't see the need, but it might be good while im in there. If so anyone know where a good kit can be found for our 5.2L v8 Magnum 318 motor? Ive been looking on summit racing but no luck.
Old Feb 21, 2012 | 12:26 PM
merc225hp's Avatar
merc225hp
About $300 if I remember right less tax
Good from .400- .525
Mopar part numbers.
Magnum Valve Springs P/N P5249464
Magnum Valve Retainer P/N P4452032
Valve keepers 2x P4529218 8mm valve stem, hardened, 16 pcs 12.00
Old Feb 21, 2012 | 06:15 PM
TheycallmeLaramie
So I need:
(16) 1.7 HS RR 16=$360
(16) Magnum Push Rods 16=$50
(16) Magnum Valve Springs 10.95x16=$175.20
(16) Magnum Valve Retainers 16x$9.95=$159.20
(16) Valve Keepers 2x19.95= $39.50
Total: $783.90!!
D@mn!
Last time I opened up my Valve covers, they looked good, so I'm not sure if I should go about replacing everything while I am doing the roller rockers, or just do the roller rockers have have some push rods on hand just encase the top worn.
Old Feb 21, 2012 | 06:25 PM
P1NKST@FF's Avatar
P1NKST@FF
I know valves aren't good things to push and test because they can cost you a lot in a hurry but since the rockers are designed for stock use and the motor doesn't spin all that fast does anybody really think that springs and stuff should be rplaced for this mod?
Wombat Ranger's Avatar
Wombat Ranger
Laramie:
Don't put that kind of money into that high mileage motor. Slap the 1.7's in there(if you want), and be prepared to be throwing another motor in the general direction of your driveway in the near future.
Old Feb 21, 2012 | 07:28 PM
TheycallmeLaramie
Thanks for your input, thats what I was thinking. I want to do the HS 1.7 as a project + to help out the engine a little with less friction. I dont want to spend 800$ when a new crate engine is 1,500$. If i get the new engine in the near future, I can get one that is not dressed up, and use all my new parts including the 1.7 RR's. Was hoping to save up and get a Ramzilla Transmission and a new crate engine at the same time . I was thinking to spend the 50$ on push rods and maybe change those out if I see that any the the tops are worn out. That wouldn't be too excessive.
Old Feb 21, 2012 | 07:39 PM
Wombat Ranger
Link to the $1500 crate?
