ABS Relays
Old Feb 21, 2012 | 11:05 AM
grox's Avatar
grox
Default ABS Relays
I was checking a fuse in the underhood fuse box, and noticed that my truck doesn't have the relays for ABS. Should those be there?
Old Feb 21, 2012 | 11:09 AM
Relays I think were only installed on trucks with 4wal. You probably just have RWAL.
Old Feb 21, 2012 | 11:10 AM
gdstock's Avatar
gdstock
Do you have 4 wheel ABS? If so, then yes. If not, then no. Same PDC is used.
Dang ..... Hey You is quick.....)
Old Feb 21, 2012 | 11:59 AM
grox's Avatar
grox
Cool. Thanks for the answer.
Old Feb 21, 2012 | 03:33 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
I have 2 ABS fuses in the cab, left panel of the steering wheel.
I only have RWAL.
Old Feb 21, 2012 | 04:05 PM
gdstock's Avatar
gdstock
I only have RWAL.
I think I remember reading in the FSM that the fuses in PDC if you have 4w abs, and the fuses int he panel inside also feed something else but I cannot remember what it was. I looked at all of that back last May or June when I was having the ABS light issue. Mine only has the RAWL aso.
Old Feb 21, 2012 | 05:00 PM
grox's Avatar
grox
I was talking about the relays in the PDC. I haven't looked for the presence of fuses, maybe I should
Old Feb 21, 2012 | 05:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You think?
Should be a 40 amp in there. Not saying it's the problem though.
Old Feb 21, 2012 | 08:09 PM
grox's Avatar
grox
Well, there's no problem. I just noticed that the spots for ABS Relays were empty. So I guess they are only for the 4 wheel anti-lock system. I didn't even know they had that, especially not in 94'.
