Slooshing noise
Old Feb 22, 2012 | 07:04 AM
dhvaughan's Avatar
dhvaughan
wait - stop.
you have a simple problem - air in the heater core.
don't complicate it by changing the water pump or heater core or anything else unless you know something is bad or leaking (which it could be).
if you don't have any leaks letting in more air - it will work itself out.
if it doesn't work out, you may have an air leak. check your hoses and clamps and run the engine a little with the radiator cap off.
Old Feb 22, 2012 | 04:00 PM
colinbreckmang's Avatar
colinbreckmang
I already tried to burp the system, I definetly cant get the air out if there is air in it. I ran the truck for close to an hour with the cap off on a very steep incline. The Rad is topped off the resivoir is at the correct mark.
Old Feb 22, 2012 | 04:03 PM
colinbreckmang
And there is definetly no leak
Old Feb 22, 2012 | 04:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Steep hill? Just so you know , you want the right front (passenger side) up as high as you can get.
Old Feb 22, 2012 | 04:36 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by sniper dave
I have the identical problem you describe. Water pump changed 10k miles ago, and heater core changed 500 miles ago. The sounds never went away. I've come to realize that its gonna be there forever.
I know somehow someone will tie it to plenum.....that is being done on Thursday...LOL
LOL....I love it
Old Feb 22, 2012 | 04:38 PM
Augiedoggy's Avatar
Augiedoggy
this might sound retarded but you did have the heat on full blast when doing this right?
Old Feb 22, 2012 | 04:51 PM
Doesn't matter, there is no flow control valve for the heater core.
Old Feb 22, 2012 | 05:00 PM
zman17's Avatar
zman17
You are right, but both the FSM and the Haynes tell you to do so. LOL
Old Feb 22, 2012 | 05:07 PM
colinbreckmang
Yup Heats on full! I have not jacked up the passenger side but the hill was so steep, that any buble should have come out.
Old Feb 22, 2012 | 05:50 PM
Huh. Wonder why.....
