2002 no horn or steering wheel stereo control worky
Old Feb 21, 2012 | 10:27 PM
offroadjosh's Avatar
offroadjosh
Default 2002 no horn or steering wheel stereo control worky
drove the cummins the other day only to find out the horn doesn't work and the steering wheel radio controls dont work. cruise works fine. guessing clock spring? would it just go bad? oh ya no airbag light on either..
Old Feb 21, 2012 | 10:38 PM
gdstock's Avatar
gdstock
Sounds kind of like clockspring - but haven't heard of one going bad on its own. Do those things connect to CTM (does an 02 have a CTM?) Just guessing at this point.
Old Feb 21, 2012 | 10:53 PM
offroadjosh
No clue. Damn thing did this under warranty then few days later shut down and had no power to dash... if you tilted steering wheel all the way down it work(broken colum wire) soo hoping its not that this time...
Old Feb 22, 2012 | 02:07 AM
MoparMan1991's Avatar
MoparMan1991
I would say its the beginnings of a failed clockspring.
Old Feb 22, 2012 | 03:51 AM
offroadjosh
what i was thinking... or the wire harness again.. well might as well do it when i replace the dash... sad to think it is a 2002 with 70k miles... dash is furbed... the 96... has a 150k and lives out side, drives down rough gravel roads daily, gets jumped, gets wet inside and thrashed on.. dash is not cracked at all.. oh ya the 2002? fully loaded cummins that if i remember correct was over 36 new.. the 96 was in the 25k range i think. what gives? oh ya! 2002 evap core is toast... 96 one is good...2002 has steering clunk with all new front end, 96 doesnt, 2002 has crappy paint and gets waxed 2 times a year, 96 is beautiful and gets trsashed on, 2002 has saggy headliner and has gone through 2 trannys, 96 is tight and tranny is original... wtf? ok rant off now.. just saying though... oh ya!! LSD is good in my 96, in the 02 it lost the clip... hmm front end in the 96=150k and i just rebuilt it, 02? 65k and needed rebuilt.. oh well.
back on topic how can i test the clock spring? suppose i should go out and do a gauge cluster test to rule out any issue there. i know the wipers and signals worked. cruise works, but horn and stere steering wheel controls dont.
Old Apr 5, 2012 | 08:18 PM
qurta's Avatar
qurta
I have a 2002 grand caravan with Airbag Light on, Cruise control not working, and also the Horn doesn’t work. Any suggestions!
Old Apr 5, 2012 | 09:18 PM
That sounds a LOT like a clock spring.... (in the column.) might wanna post in the caravan section just to be sure though......
