Couple things I would like to fix on my 1996
Old Feb 22, 2012 | 04:19 PM
dallas.yurek's Avatar
dallas.yurek
Default Couple things I would like to fix on my 1996
1) Headlights are on and when I turn the truck off and get out there is no warning chime telling me I forgot them on.
2) When I open the driverside door the dome light does not automatically come on, I can manually turn it on.
3) My cruise does not work. I told my mechanic that I read some stff online about the vaccum line under the battery causing this and he said he checked it out and replaced it and it is not the problem.
Thanks in advance for any help
Old Feb 22, 2012 | 04:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
#1 , Replace the headlight switch and check the wire harness on back of it when doing so.
#2 , Replace both the door jamb switches, they are cheap.
#3 , Check for vacuum leaks elsewhere, and read this thread. https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Also, a bad brake light switch can cause CC problems.
Old Feb 22, 2012 | 07:20 PM
dhvaughan's Avatar
dhvaughan
headlights on warning- i'm not sure where this is on a 96, but on my 01, a missing fuse in PW, PL will kill power to the CTM which kills the chimer warning for all functions including door open/key in switch, low fuel, seat belt, and lights on. if you don't turn up anything else, you could remove and open the CTM and see if the previous owner cut the chimer/dinger out of it. but- fix all missing fuses first. those burned my *** one time.
cruise must have vac at the canister thingy under the battery. double check it as its the most common failure. also as zman said, the brake switch is a trip point and also the clutch switch is a trip point in a manual trans, there's also a fuse for it, check that. beyond all that, it can be hard to identify its failure. on my son's honda i finally gave up and took it a shop where after a lot of work they were able to identify the clutch switch was open.
Old Feb 22, 2012 | 11:37 PM
jswain's Avatar
jswain
On the cruise control, I wonder how the mechanic checked it... Mine didn't work, and I changed the servo under the battery tray with a scrap yard piece and lucked up and fixed it. Actually, cruise would set and then slowly lose speed. The servo deal was leaking. If you try to set the CC, does the green cruise light come on in the dash? If the light comes on, I think it would almost have to be a vacuum problem...right?
Old Feb 23, 2012 | 07:54 AM
jam23's Avatar
jam23
I know that on my 88 f150 I removed the chimer because it was annoying the hell out of me. Check to see if the previous owner removed it too. It should be located on the drivers side dash next to the fuses. Check the drivers side door switch for continuity. It should be a "Normally closed switch" I believe. Put an ohm meter on it and make sure there is no continuity when closed and continuity when open.
Both of these should be easy fixes for you.
I am not too familiar with the cruise control on our trucks. Mine has not given me problems yet. **KNOCK ON WOOD**
Old Feb 23, 2012 | 09:38 AM
dallas.yurek
Default cruise
I think the first 2 issues are attributed to the door switch, it looks like it is broken and I will get a new one over the weekend.
The cruise, can anyone tell me where I will find the brake switch referenced above? How will I know the switch is bad, will the brake lights still work? I am not sure what my mechanic did to check the vac. but he had it twice now for this issue and was pretty convinced the last time he fixed it, a test drive would have told him he didn't but... the on/off light on the steering wheel lights up green, I have not noticed a dash light?
Old Feb 23, 2012 | 10:13 AM
If the light on the steering wheel comes on, that means cruise is active, and the breakdown is either vacuum, or servo related. (on the 96, there is no light on the dash.)
Start the truck, pull the vacuum line that goes to the servo, got vacuum there? If so, check the electrical connectors, make sure they are clean, and tight. If all that looks good, replace the servo.
Old Feb 23, 2012 | 10:29 AM
dallas.yurek
i do have the wacky vent problem, so that should confirm the vac issue. might be time to let a different mech take a shot, how much is the cruise servo
Old Feb 23, 2012 | 10:42 AM
Would have to call and ask..... I can't seem to come up with it on advance's website.
Old Feb 23, 2012 | 04:41 PM
zman17's Avatar
zman17
JY or dealer only.
