1999 Ram Engine/Trans/PCM to 2000 Ram?
Old Feb 23, 2012 | 10:53 AM
spooky's Avatar
spooky
Default 1999 Ram Engine/Trans/PCM to 2000 Ram?
Hey All, the title of the thread says it all. I currently have a 2000 Ram 5.2L 4X4, with an impressive 235K on the odo. It is TIRED. I have the engine, trans and pcm from a 1999 Ram 5.9L 4X4 (all from the same donor truck) Will the 1999 5.9 set up be compatible with my 2000 Ram chassis and wiring?
Thanks for any help!
PS. I did use the search function and came up with a guy who wanted to do the reverse procedure in a durango. But don't know how it turned out. Thanks again!
Spooky
Old Feb 23, 2012 | 11:49 AM
If you swap it all, it should go in without an issue, everything should hook right up, and bolt right in. I think you will have to use the 99 harness, as I believe some of the connections for the trans changed in 99/00. You will have to get the PCM flashed with the correct vin, otherwise, you will have constant ABS/Brake/SRS lights.
Would be easier to just bolt the 360 in place of the 318, and then get a pcm flash for the larger motor.
Old Feb 23, 2012 | 12:30 PM
spooky's Avatar
spooky
Crap!
The trans is the biggest part of this. Can anyone confim? I thought the transmissions compatible between 1999 and 2000.
As for the engine. I called the Mopar Performace tech line and the guy there said that as long as you are working within the same year model, and both vehicles did NOT have anti-theft systems, the VIN would not be an issue. Does this make sense?
In my case both vehicles do NOT have anti-theft systems, but they are different year models, being 1999 and 2000.
Old Feb 23, 2012 | 12:52 PM
For the trans, all it is I think is the electronics. Change those over to the correct year, and it should work just fine.
The vin will be an issue regardless of anti-theft system.
Old Feb 23, 2012 | 05:06 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... No need to swap anything else over (including the PCM) except the tranny internal electrics.
Old Feb 23, 2012 | 10:38 PM
spooky's Avatar
spooky
Ok, let me get this straight. I can use the 1999 trans in the 2000 truck if I use the 2000 electronics in the 1999 trans?
Is that right?
Thanks
Old Feb 23, 2012 | 10:43 PM
Augiedoggy's Avatar
Augiedoggy
You dont even NEED to get the pcm reflashed when going from a 318 to a 360....there's a guy on youtube who did it and is still driving it over 2 years later with no issues... apparently its within the 30% adjustment ratio the pcm can tune for in closed loop... see link below...
http://www.youtube.com/watch?v=-dGHB6ewe-s
Old Feb 23, 2012 | 10:48 PM
gdstock's Avatar
gdstock
Yep. Tranny guts are the same. Just the electrical pieces inside that are different.
