fuel injector replacement
Old Feb 26, 2012 | 11:50 AM
6mpg indicates you have a bigger problem somewhere..... That is WAY outta line. How old are your O2 sensors?
Old Feb 26, 2012 | 12:51 PM
ekaplan's Avatar
ekaplan
New NTK about a week after the motor install. so prob month old. Ordered from Hughes.
Old Feb 26, 2012 | 12:52 PM
Got a scanner you can plug in, and read data with? (not codes, data.....)
Old Feb 26, 2012 | 12:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Get an inexpensive fuel pressure tester to verify. And how are you checking MPG's ?
Old Feb 26, 2012 | 01:25 PM
ekaplan's Avatar
ekaplan
No, dont have anything to read data. And I have a fuel tester just haven't put it on yet. I have to wait til I get home now. I check mpg by the odometer and gallons put in at the pump. Usually around the same. Before I did any work to this I was from 7-9 depending on how and where I was driving. Basically new everything. Used to have jet chip running 93 octane. Took it off for new motor and run 87
Old Feb 26, 2012 | 04:03 PM
ekaplan's Avatar
ekaplan
results of pressure test..video file was too large to post directly...
photobucket.com/fuelpressure
i know it's going to bounce but is that too much? and the pressure went to 42 when i turned it off and within a minute rested at 48 and dropped to where it is in the pic
how do those results look??
Old Feb 26, 2012 | 04:08 PM
Yeah, fairly normal for an older pump, etc. Pressure looks acceptable though. If the Chrysler system is anything like GM systems.... there is a 'damper' in the line from pump, before it leaves the tank, that is supposed to smooth out those pulsations..... Yours looks like it's toast. I don't know if that would give you the symptoms you have though. Kinda expensive to throw a pump at it just to test.....
Old Feb 26, 2012 | 04:10 PM
ekaplan's Avatar
ekaplan
yeah it's unfortunate that they bunched everything up in the fuel tank. poor design. i've heard that some of the pulsation is from the injectors. could a couple bad ones cause too much of a drop? i only get the misfire on the two cylinders. i have new ones down there, might swap to troubleshoot but once i throw em in, i can't return them lol i just figured if it's something down the line i'd get troubles throughout, not just those two specifically
Old Feb 26, 2012 | 04:17 PM
Pull the injectors off the cylinders in question, and inspect 'em. Merc had his clogged with crap..... also, ohm test 'em, and see what ya get. (spec is 12 ohms I do believe.....)
Augiedoggy's Avatar
Augiedoggy
Originally Posted by ekaplan
yeah it's unfortunate that they bunched everything up in the fuel tank. poor design. i've heard that some of the pulsation is from the injectors. could a couple bad ones cause too much of a drop? i only get the misfire on those two. i have them down there, might swap to troubleshoot but once i throw em in, i can't return them lol
how much did they set you back? it might have been wiser to get a rebuilt complete set for like $140... otherwise the new ones may flow more than the ones you haven't replaced.. there are fuel screen filters in each one that can plug and impede flow. mine were plugged up .. you want them to all be even and a matched set.
