Stroker?
Old Feb 28, 2012 | 02:19 PM
Yeah, 2600 bucks IS a tad expensive..... But, it's a complete kit. Bore the block, clearance for everything, and down the road you go.
Old Feb 28, 2012 | 05:42 PM
Wombat Ranger's Avatar
Wombat Ranger
Yea... Piece of cake
Old Feb 28, 2012 | 07:29 PM
P1NKST@FF's Avatar
P1NKST@FF
I want to do this but can't see the reason to take a running engine off the road and mine wont die, anxious to see results when you finish it
Old Feb 28, 2012 | 08:35 PM
kejobe's Avatar
kejobe
If you want it to die, remove the oil drain plug, start engine, press gas peddle to the floor and hold it there. It'll die in fairly short order.
Old Feb 28, 2012 | 11:54 PM
QuadCabLuv's Avatar
QuadCabLuv
This is my problem. And I can't see trashing a perfectly good motor either. But when it does go I'll be doing a stroker.
Old Feb 29, 2012 | 12:58 AM
FireDodge's Avatar
FireDodge
Is there anything wrong with just swapping out the stock crankshaft with the 4" stroke? Like keeping the stock bore...
Old Feb 29, 2012 | 02:14 AM
sinus19's Avatar
sinus19
I don't, I wanna go ALL OUT and do the 426 stroker. Either that, or maybe an LS7 Transplant.
THATS RIGHT OR A 427!!! although not sure about the LS7 transplant... I'd keep it MOPAR! but everyone has their own opinion/taste
Old Feb 29, 2012 | 02:18 AM
sinus19's Avatar
sinus19
YA!! except thats exactly wat i payed for my top end! (fully assembled heads, roller rockers, push rods, lifters, Mopar valve covers, and Cam)
Old Feb 29, 2012 | 08:41 AM
P1NKST@FF's Avatar
P1NKST@FF
Pretty sure you need shorter rods to account for the stroke, don't really see where the harm would be except the wear in the cylinder walls from the mileage... But I don't build these regularly
Old Feb 29, 2012 | 08:44 AM
On a stroker, the pistons are different too..... wrist pin location is NOT stock. Just transplanting a crankshaft wouldn't work.
