Last edit by: IB Advertising
Browse all: Electrical System
- Dodge Ram 2nd Gen How to Replace Distributor
Step by step instructions for the do-it-yourself repairs.
Any tricks to replacing the Distributor Cap on a 95 Ram 1500 4x4?
Pull the intake.
One member took off the air box, and laid a piece of plywood from the radiator support, to the throttle body. (cover it with a rag first....) and laid on that to do the cap. Looked like a good idea to me, so, that's what I did as well. works fairly well. Far more comfy than trying to fold yourself up into a pretzel in the engine compartment, and lean down far enough to be able to work on it.
I like my tire step for these kinds of things, but if I had a larger garage I'd have an overhead creeper.
Be careful you don't break the hardware getting the old one off. Apparently the screws like to seize and break upon attempted removal from what I've read here. What I do with potentially seized hardware wherever I encounter it: Whack it with a hammer (to crack the corrosion between threads), then soak it down with penetrating lubricant. And just so it's said: WD-40 is NOT a penetrating lubricant. For the itty bitties like the distributor cap screws, of course, a center punch is used. I don't often break fasteners -- the job takes a little longer than it would if everything would just come out nicely without the additional effort, but a helluva lot less time than hauling out the extraction kit and maybe the Heli-Coil kit.
Trending Topics
