headlight check
Old Feb 28, 2012 | 02:37 PM
rddmesrddmes's Avatar
rddmesrddmes
Exclamation headlight check
hi, can anyone tell me how to check a headlight switch on a 94 1500? thank you
Old Feb 28, 2012 | 02:41 PM
Pull the bezel, pull the switch, have a look at the wiring behind it as well. Do your headlights not work?
Old Feb 28, 2012 | 03:09 PM
rddmesrddmes
they just quit working all of a sudden. park lights work, insides do too, fuses good need to know how to check switch thanks
Old Feb 28, 2012 | 03:10 PM
Probably the wiring behind the switch, or, the multi-function switch on the column.... (turn signal/dimmer switch, etc.) Try tilting your wheel all the way down, and see if they work.
Old Feb 28, 2012 | 04:25 PM
rddmesrddmes
ok, heyyou, thanks buddy, i`ll check it out and update you
Old Feb 28, 2012 | 05:52 PM
grox's Avatar
grox
To check the switch you'll need an ohmeter. Just check that there is low resistance between the input terminal ('B1') and output terminal ('H') when the switch is pulled out (headlights on) and should be high resistance otherwise.
The wiring diagrams also show that you may want to also test B2 to I. They also seem to work with your headlights.
Old Feb 28, 2012 | 06:16 PM
rddmesrddmes
grox, i`m not real familiar with an ohmeter but when i tested like you said it goes from 1 .0 to 00.0
Old Feb 28, 2012 | 06:42 PM
rddmesrddmes
Default headlight check
is that low resistance? thanks
Old Feb 28, 2012 | 07:09 PM
P1NKST@FF's Avatar
P1NKST@FF
I don't know about the resistance but when something like that goes bad in my truck I try tapping it and so far it's fixed my headlight switch and blower motor, the problem is probably in the switch. A thread just got bumped where a guy with a van had to clean his, I just tapped mine with the switch pulled out and got the lights on but later the switch started to melt the connector and had to replace. Since its easy to get to I'd start by looking at that if adjusting your colum doesn't find the problem
Old Feb 28, 2012 | 07:29 PM
rddmesrddmes
ok p1nkst@ff, thanks buddy
