Is this normal? pics and video
Old Mar 1, 2012 | 10:07 PM
safrantz's Avatar
safrantz
Someone be a pal and show me a mechanical gauge at oreillys, advanced, auto zone or somewhere local through their website...I've mentioned a mechanical gauge to all these places locally and they always direct me to sunpro gauges... :/
Old Mar 1, 2012 | 10:18 PM
jswain's Avatar
jswain
Mine reads about the same on 10w30. The gas gauge does appear to be reading a little high in the second pic.
See if a shop will hook it up to a mechanical gauge for free, if you have a guy you usually go to, he'll probably help you out.
Old Mar 1, 2012 | 10:43 PM
UnregisteredUser's Avatar
UnregisteredUser
What a bunch of maroons. You don't need something high zoot -- the little dude intended to be mounted under the dash would work fine. At NAPA, it's part number BK 5011708, under $20 in most stores.
Old Mar 2, 2012 | 12:33 AM
Hylander7's Avatar
Hylander7
Normal.
My 99 5.9 reads exactly the same, fresh 10/30
So did my 94 5.9
Old Mar 4, 2012 | 11:58 PM
dodgeman2289's Avatar
dodgeman2289
mine does that all the time. even while driving goes up and down right over 40 and right below. i was told it might be my oil pressure sending unit next to the distributor.
Old Mar 5, 2012 | 08:38 AM
kejobe's Avatar
kejobe
Took this the other day. As I said mines has been doing it.
http://www.youtube.com/watch?v=_pqRq...yer_detailpage
Old Mar 5, 2012 | 11:23 AM
Mutt Bryant's Avatar
Mutt Bryant
I heard a long time ago that when you're burning valves, the oil pressure swings dramtically. I dont think its the same thing though. Just puttin it out there
Old Mar 5, 2012 | 11:26 AM
Valves won't have anything to do with it.
Oil pressure is NOT constant. The pump is drive off the cam, so, pump speed varies with engine RPM. There is a blow-off valve in the pump to prevent getting too much pressure, but, that's it. So long as pressure is 10 or above at idle, and goes up about 10 pounds per 1000 RPM, it's working as it should.
Old Mar 5, 2012 | 11:35 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, mine does the exact same thing.
Old Mar 5, 2012 | 12:19 PM
stewie01's Avatar
stewie01
I think if you look closely you can see the gas needle move a bit
