P1763 Code, Unbelievable
Old Apr 25, 2012 | 02:50 PM
  #31
georgiahemi's Avatar
georgiahemi
Default borg warner parts
Originally Posted by Augiedoggy
I though your buddy was going to check the pressure?... borg warner parts arent going to do anything but last longer than oem.... If the new dealer parts you put in didnt solve it you likely in the same boat as total war and I were in and the errors were actually telling you that you have a problem with pressure....I installed the borg warner upgrade kit from ebay prior to having mine rebuilt...
as total mentioned his fluid and sensor were clean too... he still needed to have it rebuilt to fix it...
If your wiring got damaged you should be able to test for continuity or see the damage?
Hey Augie, yeah, he is still going to check pressure before I even take those out of the package. I just wanted to have them on hand before we get into the trans pan....again. I also am making sure our local dodge dealer has the internal wiring harness too. So we are going to first check pressure out. By the way, I just cam across a P1763 diagnostics check list. I am going to post it here in a few minutes. I think this maybe something directly from Dodge. This should help a LOT of people out. We are also going to follow some of the points on this to see what happens. Let me know what you think. I am going to try and post it in the DIY section.
Old Apr 25, 2012 | 08:58 PM
  #32
Total_War's Avatar
Total_War
K
Here is the update from the Transmission Shop
They replaced the Throttle Valve in the Transmission
It kept on doing the eratic shifting, just like before I changed the Governor Solenoid
Spent the next 5 Hours troubleshooting and finally said screw it
They completely replaced the Valve Body in the Transmission with a Brand New One
Comes with all the Updated Parts I replaced on the old one, plus Borg Warner parts where it could be used
Shifting problem has completely disappeared
The Transmission shop owner is taking my truck home tonight to drive around, see if it acts up. So far they have put 50 KM and nothing
What do you guys think was the screw up here??
Obviously a spring or something stupid in the Valve Body screwed up
Electronic Problem??
They valve body was completely replaced free by the way
I didn't pay a penny, hell of a mechanic
I'd recommend him to anyone in Calgary after what he has done for me
Old Apr 25, 2012 | 09:02 PM
  #33
Actually, he needs a couple loads of dirt hauled to his house, and doesn't have/wanna use, his own truck......
Probably something sticking. Question becomes, Why?......
Old Apr 25, 2012 | 09:08 PM
  #34
Augiedoggy's Avatar
Augiedoggy
or something plugged in the valvebody....
Old Apr 26, 2012 | 10:48 PM
  #35
Total_War's Avatar
Total_War
Well
So far no problems
Shifting fine and no issues
Tested the flow of the cooler lines to the cooler/aux cooler
Perfect flow
Real test will be on a hot day
I'm tempted to tell people with code P1763 to just replace the whole valve body
Prices on eBay are barely $300. Use Borg Warner for the solenoid if it doesnt have it
Keep everyone updated
Transmission mechanic said he'd let me know what was causing the problem once he rips the old valve body apart
Old Apr 27, 2012 | 02:20 PM
  #36
95Erokram's Avatar
95Erokram
Originally Posted by Total_War
Well
So far no problems
Perfect flow
If it is a thought down the road i really do reccomend patc and theyre transmissions/ i love my rebuild backed with all of thier parts. overdrive shifts smoothly and precise, more positive power firmer shift,ffeels like a whole lot less power loss with the TQ that was used. i pulled a 5 ton semi out of mud in 4 wheel and the truck didnt even blink a week ago. i was shocked and impressed. just rolled 10k on it
Old Apr 28, 2012 | 12:58 AM
  #37
johnnyjaws98's Avatar
johnnyjaws98
Do a front and back band adjustment on the trans 1st and see what you get it will cost you notta
Old Apr 28, 2012 | 01:44 AM
  #38
Total_War's Avatar
Total_War
It was done the first time the valve body was dropped to do solenoid and sensor
Didn't help man
Old Apr 28, 2012 | 09:18 AM
  #39
Augiedoggy's Avatar
Augiedoggy
well hopefully your TC isnt starting to fail and leaving shavings to plug valve body...thats what plugged mine up but they were able to clean it during rebuild.. Something large enough to obstruct flow had to be lodged in there and shavings that big aren't normal wear and tear...
Old Apr 28, 2012 | 09:28 AM
  #40
Total_War's Avatar
Total_War
I'm under warranty for 22,000 km
If she goes, no cost to me. So far it's shifting excellent.
No hard shifting either
The transmission mechanic also ripped apart the filter
Nothing in it. Replaced it with a WiX
