Steering Knuckle replacement?
Old Mar 3, 2012 | 08:05 PM
tsmith4026's Avatar
tsmith4026
Default Steering Knuckle replacement?
Hi, I have a 2001 ram 1500 4x4 with the off road package, I need to replace the steering knuckle among other things, I found a 96 ram 1500 4x4, are they interchangeable? they look similar but different. any help would be great.
Old Mar 3, 2012 | 08:29 PM
Knuckles should be the same.
Old Mar 3, 2012 | 09:26 PM
dhvaughan's Avatar
dhvaughan
are you sure? i thought the 2000-2001 might be slightly different, due to dual piston calipers.
Old Mar 3, 2012 | 09:27 PM
Oh, good point. I don't recall if the caliper brackets bolt on, or are part of the knuckle.
Old Mar 3, 2012 | 10:00 PM
dhvaughan's Avatar
dhvaughan
caliper brackets do bolt on. big heavy double L shaped brackets. big *** bolts torqued to about 150 pounds that require a big heavy *** long pull bar to remove.
Old Mar 3, 2012 | 11:16 PM
Is that on both flavors? Is it possible to use the dual piston brackets on the older knuckles?
Old Mar 3, 2012 | 11:51 PM
dhvaughan's Avatar
dhvaughan
i don't know. my only experience is on my 01.
Old Mar 5, 2012 | 12:14 PM
tsmith4026's Avatar
tsmith4026
nope. doesn't quite fit..has hard stops for the caliper. anyone need a 96 steering knuckle and caliper..?
Old Mar 5, 2012 | 12:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you fix the problem you were having? And what was it to begin with? Just curious.
Old Mar 5, 2012 | 12:40 PM
tsmith4026's Avatar
tsmith4026
No I still need to replace the knuckle, I had a small accident. broke the lower ball joint mount on mine. along with the steering gear and a few other things.
