where to mount
Old Mar 16, 2012 | 02:27 PM
  #41
A capacitor will make the initial draw not so hard on various electrical components, however, it will not make up for an inadequate electrical system to begin with. If your lights draw more power than the alternator puts out, you WILL have troubles. Cap will just delay that for a few seconds........
How many lights do you have, and at what wattage?
Old Mar 16, 2012 | 02:37 PM
  #42
Motorizer's Avatar
Motorizer
hmmm. this truck had major electrical problems last summer while i was working since that magical week of spending 1700dollars to fix that as well as a new fuel pump and 02 senors were replaced
I have 9KC daylighters facing forward at 130 watts each so 130watts x 9= 1170 total watts ( i think that is correct) I have 4 lights facing backwards 2 are your standard cheap tractor lights that you can find at any truck stop not sure of the wattage and the other 2 I have no idea of the wattage or brand at the moment
Old Mar 16, 2012 | 02:40 PM
  #43
TC3EMTB's Avatar
TC3EMTB
Heyyou was correct in a way capacitors wont act as a battery it just delays the inevitable of the charging system breaking and randomness burning up.
you have 3 real options on fixing the problem completely instead of just doing a bandaid on it
1: convert all lights to LED(hella expensive)
2:LED bulbs
3: Second charging system like ambulances have.
the capacitor stores the amount of voltage the system puts out, and when you use it it drains down. it essentially would only help you if your truck shut off and you had all your lights for maybe about 3-5 minutes depending on the amp draw.
  #44
Just with your KC lites you are pushing 100 amps........ I would seriously consider upgrading the alternator........
Old Mar 16, 2012 | 02:42 PM
  #45
Motorizer's Avatar
Motorizer
I just asked the guy that gave me the two bright lights that are facing backwards on my truck he said they are aircraft landing lights
Old Mar 16, 2012 | 02:44 PM
  #46
Motorizer's Avatar
Motorizer
2:LED bulbs
oh alright i was looking into converting them all to led's but they are the pencil beam lights, i was told LED's dont throw light that far (not sure if that is correct just what i was told)
Old Mar 16, 2012 | 02:45 PM
  #47
Motorizer's Avatar
Motorizer
Looks like I will have to for now I only use 2 lights at a time, when i use them and its with the truck on and its usally for no longer then a few minutes.
If I do this I want it to be done correctly, I eventually want to run a duel battery setup because I will be getting a warn which before to long. What alternator should i start looking into?
Old Mar 16, 2012 | 02:49 PM
  #48
TC3EMTB's Avatar
TC3EMTB
you have anywhere between 1300 and 1700 watts in extra lights. which is roughly 108.33 amps to 121.42 amps
best option now that i could do some math is to get a high out alternator and a second battery and do the ambulance set up. the most amperage for a single alternator for stock replacement is only 120a which wouldnt even cover all the lights if they are all 130w
  #49
gdstock's Avatar
gdstock
The heaviest duty alt that you can fnd. But remember the PDC is fused. I think it is 140A.
Old Mar 16, 2012 | 02:50 PM
  #50
Motorizer's Avatar
Motorizer
oh yeah im not sure if this is need to know information or not, But im also running inside the truck my GPS police cobra radar, and my cobra cb and sometimes cell phone charger
