truck hesitated to move
ok thanks i should of typed torx and not hex but the 2 screws that hold the tps on are like these?http://www.psxboy.com/syssite/home/s...mg/big/743.jpg
if so then i found the right part just want to make sure before i check it this week.
i got another question I called advanced and auto zone the tps is $33.95 and like $66.95 for a tps with a life time warranty.then i called the dodge dealer and they have one made by dodge for $133.95 why so big of a price hike?my buddy tells me to get the one from the dealer cause they looked the part up by my vin number and it will be an exact match made by mopar.you think the $33.95 one from advanced is good enough or should i go buy the tps for $133.95 from the dealer?what one would you buy?does it really matter?
also forgot to ask where is the maf located on my truck is it in the housing where the air filters located?I want to clean it and cant seem to find it.thanks...thanks ill try napa theres a napa a few towns away from me and see if they have a tps.
I don't know where Chrysler gets their stuff, but Delphi is an OEM supplier for several parts for several manufacturers. I've been using their aftermarket repair parts since the 1960's with never a complaint.
thanks for the pics that really helps.how do i go about cleaning the MAP? Do i remove it and spray it?what wire and connector the can of map cleaner said something about sprying the wires also never did this before so i dont wanna screw it up.also do you ever have to replace the map with a new one or can you jsut clean it?just wondering.
