Freeze plug...crapped itself
Old Jul 20, 2012 | 08:10 PM
  #31
safrantz's Avatar
safrantz
Told ya ya should have done it when you were there.
Ah well... I've been watching YouTube all night on the similar subject... I kind of want an engine hoist now... ah well. So you stood the 6" 2x4 vertically to jack up into the oil pan frame rail? Seems dangerous, but I'll try anything once (hopefully I come back with good news!)
Old Jul 20, 2012 | 10:11 PM
  #32
Yeah, just be careful. And make sure the board is nice and straight, so the weight doesn't just spit it out. That would be bad.
Old Jul 20, 2012 | 11:19 PM
  #33
S S0DEN's Avatar
S S0DEN
Originally Posted by Crackshot
Freeze plugs rot out like that because antifreeze actually turns to acid if it is not changed.
This is why radiator and antifreeze flushes are important.
Keep us posted how it works out!
They rot because they are white metal and are prone to oxidization. Brass does not oxidize at the rate of white metal or steel.
Old Nov 24, 2018 | 06:45 PM
  #34
Steven Mcalister's Avatar
Steven Mcalister
just read your post made me remember when i was a kid back in the 60s we were going over the grapevine in Calif my pops 59 chrysler big block and blew the soft plug he took a silver dollar and used it to replace the old plug. it worked i just wonder if anybody ever found it it had to bring a smile to there face.
Old Dec 2, 2018 | 11:54 AM
  #35
dog dodge's Avatar
dog dodge
ive a 2000 truck 5.9 gas and doing the freeze plug drivers side behind motor mount . oreily web site says its a 1.25'' shallow cup but i read here its a 1 5/8'' ?
Old Feb 28, 2021 | 06:27 PM
  #36
raychrl's Avatar
raychrl
Can you give some more detail on how you replaced the freeze plug behind the motor mount? I have to replace mine- drivers side behind the motor mount 2001 Dodge Ram 1500 5.2l manual. Thanks, Charles
Old Feb 28, 2021 | 06:35 PM
  #37
Loose the motor mount bolt, the mounts are slotted, so you don't have to pull it all the way out. Jack up the motor so you can get access to the bolts that hold the mount on, remove the mount, do what ya gotta do to get the old one out. (I just stabbed a big screwdriver thru it, and pried it out...) clean the hole with some sand paper. (keep in mind, unless the cooling system is drained before you start, yer gonna get wet, and even if you drain it, you are STILL gonna get wet.....) put some RTV around the perimeter of the new freeze plug, and drive it into the hole. I used a big socket, that fit inside the plug, and a short extension to tap it in. Worked great.
Old Mar 1, 2021 | 12:09 AM
  #38
raychrl's Avatar
raychrl
I can't tell you what a huge help that is. I was convinced I was going to have to get someone to lift the engine for this. Thanks, Charles
