Fastman t body 50mm
Old Mar 5, 2012 | 04:40 PM
Lemunman's Avatar
Lemunman
Default Fastman t body 50mm
Hey guys just wanted to show my fastman throttle body 50mm
And write a review so far
1.shipping took a few weeks lack of material to finish it.
2. Finally received need to be signed for (nice)
3. But I must say where the s bolt goes and inside the bores. There's is an alarming amount of pits kind of scary looking
So I called danial and he had remembers that my t body had more then normal pits but he didn't think it was bad enough to worry about. He reassured me I had nothing to worry about . Also that he has a lifetime warranty safeeee!!!
Just put it on will update later
Old Mar 5, 2012 | 04:53 PM
Lemunman's Avatar
Lemunman
Default pits
Attachment 15625
Old Mar 5, 2012 | 07:15 PM
lastrights's Avatar
lastrights
Does it still work and fit ? I bought mine 6 years ago and I loved the pep it gave . The craftmanship looked good too
If it don't work I'm sure he will send you a new one , he pretty good at making his customers happy
Old Mar 5, 2012 | 07:20 PM
Augiedoggy's Avatar
Augiedoggy
Looks cosmetically much cleaner than I was able to do with 2hrs and a dremel but for under $30 including the cost of the extra junkyard throttlebody and dremel bits I'm happy as it should perform the same and no one sees it under the air cleaner anyway... Most people dont realize the stock units are 50mm and its the extra tapered down section about the butterflies that just needs to be ground away to open up the holes a full 50mm all the way down... and of course cutting the air horns off helps flow
I started a thread about it when I did it saturday morning..
Old Mar 5, 2012 | 07:54 PM
Lemunman's Avatar
Lemunman
Would you guys be cOncerned?
Old Mar 5, 2012 | 08:29 PM
Augiedoggy's Avatar
Augiedoggy
with the pitting? no its cosmetic... doesnt effect performance at all...
Old Mar 5, 2012 | 08:32 PM
ramthis9501's Avatar
ramthis9501
I got a 50mm tb about a month ago and I love it! Throttle response is much better!
Old Mar 5, 2012 | 09:14 PM
Lemunman's Avatar
Lemunman
Okay just wanted to make sure thanks guys I look forward to it. I will write a review
Old Mar 5, 2012 | 10:23 PM
lastrights's Avatar
lastrights
I think stock bores is 48 not 50 ?
Old Mar 5, 2012 | 10:26 PM
ramthis9501
Starts at 50 and goes down to 47 below the blades
