Tire rub
Old Mar 6, 2012 | 09:42 AM
mccart's Avatar
mccart
Default Tire rub
When i turn the wheel all the way my tires rub. What is what they rub on exactly called? I cant find the official name anywhere.
Old Mar 6, 2012 | 09:45 AM
Probably the lower control arm. What size tires?
Old Mar 6, 2012 | 09:57 AM
mccart's Avatar
mccart
Old Mar 6, 2012 | 10:03 AM
That's why.
Wheels with slightly less backspacing might help.... or, they might just change where the tires rub. (wheel well, or bumper instead of control arm.....)
Old Mar 6, 2012 | 10:08 AM
mccart's Avatar
mccart
Also im going to put 305 70 16 on it in the next few weeks. What backspacing for a 10 inch wide wheel will i need to look for to minimize the rubbing? Im want black 8 hole wheels. The least back spacing i have found in that style is 4.5
Old Mar 6, 2012 | 10:10 AM
mccart's Avatar
mccart
^^^And 3 inch lift
4.5 is pretty much what the stock rims are. The 305's are going to be wider than what you have on there now.... so, higher likelihood of tire rub on hard turns. 4", or 3.5" would be better...... I do NOT recommend spacers......
Old Mar 6, 2012 | 10:12 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Some years have limiting bolts on the steering knuckles that can be adjusted. On a side note, it would also be nice if you added the info about your truck to your sig and profile. We know nothing except for it's a Dodge. Is it even 4wd? Stock wheels? I don't think I've ever seen anyone complaining about rubbing with 285's on stock wheels, rubbing the control arm.
Old Mar 6, 2012 | 10:21 AM
mccart's Avatar
mccart
Sorry im on my phone on the mobile site. 1997 half ton, It is 4wd, stock wheels. My dads which is the exact same truck does the same thing with 265s.
Old Mar 6, 2012 | 10:28 AM
zman17's Avatar
zman17
Add the info to your profile, and it will show up on the right top of your post's even when you are on the phone.
Anyway, 265's really should not rub. Check for those limiting bolt's.
