ring and pinion question
Old Mar 7, 2012 | 05:27 PM
offroadjosh's Avatar
offroadjosh
Default ring and pinion question
so i got my carrier out of my axle and got a few questions. My pinion gear is chewed up a bit so i may end up getting a set of used junk yard gears(same ratio of course). Is it ok to run a set of used gears? Also i may put it back together until i can afford gears or if i sell it. what do i need to do before reinstalling? can i just put it all back together since i all i did was replace the cross shaft in the spiders?
Old Mar 7, 2012 | 05:32 PM
Yep, just put it back the way it was with the shims and such (if any) and you should be golden. Check the pattern before buttoning it up. If it looks ok, run it. If it's noisey..... might wanna have another look.
Old Mar 7, 2012 | 05:42 PM
offroadjosh
Thanks! Thinking i will toss it together and see if the pinion is damaged enough to screw the pattern up at all. if so ill be going down that road then. if it looks good ill just run it lol. Seriously time for one tons since im breaking internal parts now...
Old Mar 7, 2012 | 05:50 PM
Too bad you aren't closer.... there's a 97 in the yard here, with D60's......
Old Mar 7, 2012 | 06:25 PM
Augiedoggy's Avatar
Augiedoggy
Whats wrong with the 3500 in your signature? or isnt that yours?
Old Mar 7, 2012 | 06:44 PM
offroadjosh
damn! and nothing is wrong with the 3500:P its my haulin truck so i only use it when i tow...
