Speedometer isn't working
Old Mar 9, 2012 | 02:57 PM
Racer527's Avatar
Racer527
Question Speedometer isn't working
I have 1996 318 1500 ram the speedometer isn't working right till 3-5 miles before it kicks in and the tech, fuel, oil, temp works fine can anyone help me out with this
Old Mar 9, 2012 | 03:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Any other lights on? As in ABS or Brake lights? How does it shift through the gears? There are 2 sensors that can be the problem. Speed sensor on side of tranny and speed sensor on top of rear diff.
Old Mar 10, 2012 | 12:38 AM
Racer527's Avatar
Racer527
it shifts fine none of thoes lights are on
Old Mar 10, 2012 | 12:47 AM
Racer527's Avatar
Racer527
sorry also the sensor on the tranny has been replaced
Old Mar 10, 2012 | 09:35 AM
If you aren't getting a CEL, and none of the other lights are on, may be a cluster problem.
Old Mar 10, 2012 | 12:05 PM
Racer527's Avatar
Racer527
the abs, brake lights aren't on but all of the other lights are working through
Old Mar 10, 2012 | 02:29 PM
zman17's Avatar
zman17
I'd replace the sensor on the rear diff anyway.
Old Mar 10, 2012 | 04:48 PM
Racer527's Avatar
Racer527
just replaced the one in the rear diff and it still hasn't changed also it started to buck once again
Old Mar 24, 2012 | 01:00 PM
Racer527's Avatar
Racer527
what would cause the starter relay cut out
Old Mar 24, 2012 | 09:33 PM
gdstock's Avatar
gdstock
Originally Posted by Racer527
...... it started to buck once again
What does that mean?
