Doin' brakes.
Old Mar 9, 2012 | 04:54 PM
vengeancex's Avatar
vengeancex
Default Doin' brakes.
So I'm doing my brakes and I noticed something.
The outer brake I just took out didn't seem right. The clip near the end of the brake was downwards. and the 2 inner clips that snap into the holes weren't lined up.
It looks like it was half assed. The new brake I put on is facing up wards and the clips are in properly.
Is that clip near the end supposed to be on the bottom of the caliper?
Old Mar 9, 2012 | 05:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You should only take one side apart at a time(so you have the other for reference) did you do that?(and your description is pretty useless without pics) And in the FAQ/DIY section there might be a DIY for your year truck. If not, try a search here on DF(yea I know the search feature here sucks).But there is threads with great pics. Other than that, you should have a Haynes and download the correct FSM for your year truck from the FAQ/DIY section.
Old Mar 12, 2012 | 05:12 PM
vengeancex's Avatar
vengeancex
So since I replaced my brakes, I drove about 80 miles with them and they still keep smelling like they're burning. Before my other brakes didn't make that smell, but they were really worn down. I highly doubt my caliper is bad. The truck brakes fine, it's just after while they smell like it's burning and when I came home I felt the tire and it was hot. Not burning hot, but pretty hot compared to the back tire.
Old Mar 12, 2012 | 05:19 PM
Jack up the front, step HARD on the brakes. Release the pedal, and see how hard it is to turn the wheels.
Old Mar 12, 2012 | 05:49 PM
vengeancex's Avatar
vengeancex
Guess I was wrong. Jacked up the truck, pressed on the brakes. The tire BARELY spun after I turned it hard.
Time for new caliper? LOL
Old Mar 12, 2012 | 06:35 PM
Do the same test, when the brakes seem to be sticking, open the bleeder valve. If the brakes immediately release, the soft lines are the problem.
Old Mar 12, 2012 | 06:49 PM
vengeancex's Avatar
vengeancex
If I open the valve won't I let air in the system?
I'm not a fan of bleeding the brakes LOL
Old Mar 12, 2012 | 06:54 PM
Look at it this way, you have a problem, that is going to require bleeding in any event. If you just crack open the valve, a bit of fluid may come out, but, so long as you DON'T step on the pedal with the valve open, it'll be ok.
Old Mar 12, 2012 | 07:15 PM
vengeancex's Avatar
vengeancex
Okay, I jacked up the truck and I steped on the brakes, opened the bleeder and no fluid came out, nor did the brakes release -_-
Old Mar 12, 2012 | 07:17 PM
Caliper is seized then. Or, the bleeder is clogged full of crap, and won't let fluid out.
