ac issues
Old Mar 12, 2012 | 04:38 PM
cutthroatxxx's Avatar
cutthroatxxx
Default ac issues
Ok well..awhile back the two prong plug that goes to my ac one of the wires got rippd off awhile back so I spliced it back together&ac clutch wouldn't engage.So today I took a test light &grounded it&touched the end of the light to the wire that was spliced&boom it kicked on...seems like a ground issus.Is there a ground Im missing maybe?
Old Mar 12, 2012 | 04:43 PM
PCM grounds the circuit. Is the system charged?
Old Mar 12, 2012 | 04:47 PM
cutthroatxxx
Its charged if I jump it with the light it gets good&cold
Old Mar 12, 2012 | 04:49 PM
Might be one of the pressure switches have failed..... Not sure which side of the circuit they are on though.....
Old Mar 12, 2012 | 04:53 PM
cutthroatxxx
Pressure switch?idk worked the day before I did my plenum wondering what I could of did?I was gonna nust replace the switch but dont wanna waste money.If I have to guess I can just jump it&run a toggle switch if need be.
Old Mar 12, 2012 | 05:04 PM
If you have power at the compressor, everything is working correctly. The white wire just runs off to ground somewhere.
Old Mar 12, 2012 | 05:06 PM
cutthroatxxx
What white wire?the two Im talking about are green
Where they at?
Old Mar 12, 2012 | 05:08 PM
cutthroatxxx
my bad the two prong plug on front of compressor
Old Mar 12, 2012 | 05:09 PM
Ok, I see where yer at. Yeah, if the system operates properly if you bypass the switch, replace it. There are two though, one on the high side, and one on the low side. Make sure you get the right one.
