Tranny sensor and solenoid replaced, but still acting up.
Old Mar 13, 2012 | 09:26 AM
blackbeasst's Avatar
blackbeasst
Default Tranny sensor and solenoid replaced, but still acting up.
but its only first gear that seems to be funky. still seems to jerk on occasion as well as rev high and then slowly shift to 2nd. everything else shifts fine.
anything else need to be checked?
Old Mar 13, 2012 | 09:28 AM
Band adjustment?
Old Mar 13, 2012 | 10:57 AM
blackbeasst
Band adjustment?
he said he did that whilst in there as well
Old Mar 13, 2012 | 10:58 AM
That's why I like these things to stay in the same thread.
Old Mar 13, 2012 | 11:53 AM
gdstock's Avatar
gdstock
I am still looking for band adjustment........Not going to research old threads though....but that's just me.
Old Mar 22, 2012 | 09:57 AM
blackbeasst
and since this post it has only gotten worse. i drove it back to the tranny guy this morning and a couple times it wouldn't even move off the line at a light. just revved up. and other times it wouldn't get out of first.
when i finally got there he said that more then likely the way that band was so out of adjustment when he replaced the sensor/solenoid that more then likely the band is shot and needs replacing. to the tune of about $700.
im about ready to sell it as-is and be done with it
Old Mar 22, 2012 | 10:06 AM
700 bucks for a band replacement? That seems a bit extreme.... If he is going to tear it down that far, rebuild the trans. Or, slap a junkyard trans in there for a couple hundred, and rebuild the original yourself. Or.. spend the big bucks on a Viper.
Old Mar 22, 2012 | 11:02 AM
billcart's Avatar
billcart
I have been chasing my transmission problems for years now. I finally broke down and had a local shop rebuild it with the alto steels and a sonnax shift it. WOW is all I have to say. You can change the fluid every 10-15k and it will run forever (with lots of probs) but in the end you have to do some upgrades to it in order for it to last. Mainly the gear ratios in the rear (and front for 4x4's). These trucks DO NOT like the 3.55 stock gears. I recommend 4.10 for the 2x's and 4.56 or better for the 4x4's. Just my own opinion. It's not like I am on my 2nd 4x4 ram or anything, oh wait! I AM! lol
Or you can be smart and do what HeyYou said and get the VIPER! If I had the dinero I would. My rebuild was 2900 with all the upgrades and I made them replace the u joints front and rear. Considering I flushed my transmission every 10-15k for the last 6 years I should have done this years ago. Oh yeah, don't forget to get an external oil cooler.
Old Mar 22, 2012 | 11:40 AM
blackbeasst
yeah i thought so too. but he said a complete rebuild is $1200 but that seems too cheap
Old Mar 22, 2012 | 11:49 AM
Rebuild prices are all over the place. 1200 doesn't seem unreasonable. But, that is prolly for a stock rebuild, using stock quality parts..... which were inadequate when the truck was new..... Without doing some upgrades, I don't think a rebuild is worth it.
