94 cranks too long and runs rough??? Help!
I have done a bunch of searching but did not find any symptoms like mine. Any help is much appreciated!! Yestereday I got in my 1994 Dodge 1500 4x4 with 5.9 gas (165,000 miles) and it started just like normal. I drove to the store and when I got back in to start it it kind of coughed like a small backfire. When I tried to start it again it cranked for about 10-12 seconds before it started. It acted like it was flooded. I went on my way to town and when I got back in to start again, same thing. On my way home it seemed to have a miss under a load. I could stomp the pedal and it seemed to run ok. When I try to start it it cranks fine but does not want to start until I touch the gas pedal. Sometimes it will start, and sometimes it just seems to diesel. It had a new fuel pump installed about 4 months ago. With a pressure gauge attached to the schrader valve I have 42 psi with the engine running. It did not bleed down when I turned the truck off. I took off the throttle body and cleaned everything good, including removing the IAC and cleaning it. I have no CEL and I am stumped. Any ideas?? Thanks in advance!!
Well checked out GPS and it was fine. While my head was under the hood with the key on I heard a very annoying high pitch tone. It was coming from the ECU. When I turned the key off it quit. But when I tried to start it no luck. Just cranks now. Should I hear the ECU? DRIVING ME CRAZY!! THANKS!
Trending Topics
