Truck dies, wont idle until warm
Old Mar 21, 2012 | 11:42 PM
15austin's Avatar
15austin
Default Truck dies, wont idle until warm
Went to start up the ram today, it will crank but wont start till i push on the gas pedal. It will run fine as long as the gas pedal is slightly pushed but soon as i let off it dies. After i drive it down the road a bit it idles fine. What could be the problem?? Thanks
Old Mar 22, 2012 | 09:50 AM
Plugged up IAC port, or failing IAC motor, or bad TPS. Take the throttle body off, and clean the IAC, and it's well. (leave battery disconnected while you do this.) Put it all back together, and see if that doesn't help.
Old Mar 22, 2012 | 10:27 AM
FLARAM's Avatar
FLARAM
Load test the battery also, it may be that it's on it's way out.
Old Mar 22, 2012 | 10:49 AM
billcart's Avatar
billcart
I have had that problem time and time again when my truck hit about 25k. It is most likely the idle air control valve. Take the TB off remove the IAC and clean it with mass air flow sensor cleaner. With a brass wire brush GENTLY clean the plunger of the IAC and with a little more cleaner. While that is drying remove the other two sensors and clean the s**t out of the throttle body with a tooth brush, brass wire brush and berrymans throttle body/carb cleaner until it no longer has any build up on it. Not to say that is the definite fix for you but it is the easiest start for diagnosing those types of problems. I clean mine every other oil change. The gasket is reusable most of the time but it might be a good idea to get an air filter housing gasket and a TB gasket just in case. I wouldn't hurt to have them in the tool box anyways. These throttle bodys are very easy to remove and clean. People complain about the dodges but I don't. My wife has a 2k Tundra 4x4. Except for the motor and dashboard the rest of the truck is a POS!
Old Mar 22, 2012 | 04:21 PM
zman17's Avatar
zman17
Retired Moderator - RIP
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Mar 22, 2012 | 08:45 PM
15austin's Avatar
15austin
Wow ask and i shall recieve. Thanks guys ill clean the iac and hope that will work. My battery terminals were shorting out ans i cleaned em yesterday maybe that was part of problem. Thanks alot
Old Mar 25, 2012 | 06:25 PM
Wombat Ranger's Avatar
Wombat Ranger
Did cleaning the IAC help?
Old Mar 25, 2012 | 06:59 PM
gdstock's Avatar
gdstock
Not just dirty and cooreoded or shorted terminals.....Have the battery load tested. It has to be good and hot! And +1 more on the IAC and TPS. Good starting points.
Old Mar 26, 2012 | 08:05 AM
15austin's Avatar
15austin
Fixed. Cleaned iac it was real dirty. Seems to be idling great now. Also gave the battery a good cleaning.
Old Mar 26, 2012 | 11:58 AM
billcart's Avatar
billcart
Good to hear. If you use a K&N drop in make sure you clean it every oil change.
