46RE slipping after filter/fluid/gasket
Old Mar 25, 2012 | 03:21 PM
moss500berg's Avatar
moss500berg
Default 46RE slipping after filter/fluid/gasket
I recently changed out my filter and fluid in my truck, now whenever i take off from a stop it starts slipping, but once im moving it does fine, i can floor it around 35-40mph and itl hook up 1st and take off. It wont even spin the tires in gravel in forward or reverse gears, like it used to before the fluid/filter change. The transmission supposedly has around 87k miles on it.
Could this be a simple band adjustment? Or are the clutch paks going out?
Any help is greatly appreciated.
Old Mar 25, 2012 | 03:29 PM
dhvaughan's Avatar
dhvaughan
recheck fluid level with engine running and trans in neutral and make sure you're looking at the lowest point on the stick. it sounds low.
Old Mar 25, 2012 | 04:52 PM
gdstock's Avatar
gdstock
Let us know if that's the problem....sounds like it...
Old Mar 25, 2012 | 06:41 PM
ryan0714's Avatar
ryan0714
yup sounds low fluid level, mine did the same thing i was like wtf i know i didnt let all freakin 5 qts leak out, but more comes out than what u think i guess.
Old Mar 25, 2012 | 07:05 PM
lastrights's Avatar
lastrights
Did you stick to using the Chrysler brand ?
Old Mar 25, 2012 | 08:07 PM
moss500berg
Ill go check it again, and no i didnt use chrysler brand fluid
Old Mar 25, 2012 | 08:15 PM
gdstock's Avatar
gdstock
Make sure you use ATF+4. Brand doesn't matter, but type does matter.
Old Mar 25, 2012 | 08:37 PM
moss500berg
Yeah i used +4, just checked it and its actually a little above where its supposed to be. Still not getting much power to the ground from a stop.
Old Mar 25, 2012 | 08:44 PM
lastrights's Avatar
lastrights
Did u disconnect any sensors ?
Old Mar 25, 2012 | 09:09 PM
moss500berg
No not that i know of, is there a particular sensor that could cause this that could be shot?
