How to repair a hole in a battery
My battery fell into the belt and burned a nice hole in the side, it's not horrible but it does leak battery acid. The battery still works great and the one cell it affected doesn't seem to be bad. I've tried epoxy to cover the hole in the plastic but the acid just ate through it, any ideas on a permanent solution? Also can you buy battery acid to put inside? Thanks a lot
Lol I'm still in highschool, but i read somewhere that you can melt the handle and it's the same material so do you think it's worth a shot? If not I have a warranty on it, idk if they'll replace it though
Trending Topics
Not worth it. Bear in mind, the battery generates hydrogen gas, which is just a tad flammable...... exploding batteries are just bad.......
Bite the bullet, buy a new battery, I seriously doubt warranty will cover the hole. And, as stated above, get a battery hold down thingy.
