loud grinding sound from front wheel
Old Mar 31, 2012 | 02:59 AM
2000ramsport's Avatar
2000ramsport
Question loud grinding sound from front wheel
tonight on my way home my truck made a loud grinding sound from the front drivers side wheel.it only made the sound when the truck went real slow like 5 to 10 mph it was so loud people in the parking lot turned around and looked.it did it going forward and reverse.it was so loud i got a tow truck to tow me home.I looked at the brake pads and there at least 50 percent.it kinda sounded like if you step on a lose board and it makes that creeping sound but alot louder.anyone have any clue to what this could be?
Old Mar 31, 2012 | 05:29 AM
Ram_King's Avatar
Ram_King
Sound like a bad wheel bearing.
Old Mar 31, 2012 | 10:53 AM
mantisman51's Avatar
mantisman51
Did you physically remove the pads from the caliper/rotor, or did you just look at them while they were still installed? Several years ago I had the same thing happen on my way home from Sun Valley, Idaho. All the twisty mountain roads and wide open straightaways, no problem. Then out of the blue the front end started this LOUD grinding/scraping noise. When I pulled the tire off, I couldn't see anything but maybe 50% pads by looking with it installed so I took off again, but the noise was just as bad. I pulled the tire and caliper off and on the bottom side, toward the inside, the pad had broken and the rivets were gouging into the rotor. The pad had worn crooked on that side and when it broke it was cocked in the caliper but I couldn't see it because of the dust plate. If it's not the pads, bearings usually don't just start making a loud noise, but if so simply jack up the front end and put one hand on top and one hand on the bottom of the tire and jerk the top then the bottom back and forth intermittently. You would most likely here popping or feel slop. It should be tight, with no looseness and no popping or clunking. I would look for debris in the caliper/rotor area, especially behind the dust plate.
Old Mar 31, 2012 | 03:19 PM
2000ramsport
yeah i think its the wheel bearing also the pads are ok.im going to take the wheel off monday dont have time today cause of other things to do.
Old Apr 4, 2012 | 06:59 PM
2000ramsport
turns out its the Wheel Hub Assembly it will barley turn if you turn it as hard as you can with your hand .looks like the rust got to it from 11 years of salt and sand from winter roads up here in ct.guess thats why I was getting that loud sound.me and my buddy
ordered a new wheel hub assemly today for it will pick it up after work thursday.i know this may soudn dumb but does the new wheel hub assembly come with a new whee bearing?im guessing it does but had to ask as i might as well replace that to while i have it all part.also my truck is missing th brake dust sheild on that side does it really have to be there or should i order a new one?just wondering thanks.
Old Apr 4, 2012 | 08:18 PM
Yeah, the hub/bearing assembly comes as one piece. The tricky technospeak term is "unit bearing"..... whoopee. They can be fun to separate from the knuckle...... lots of threads relating to that though.
Old Apr 4, 2012 | 08:33 PM
JackJ's Avatar
JackJ
Remove hub bearing, metal chisel, BFH, muscle.
Oh yeah, three bolts as well.
dhvaughan's Avatar
dhvaughan
this is you.
http://www.pavementsucks.com/tech-article-5.html
http://www.pavementsucks.com/tech-article-3.html
