Thread in style e-fan temp sensor question
Old Apr 1, 2012 | 12:53 AM
Silver Bastard's Avatar
Silver Bastard
Default Thread in style e-fan temp sensor question
Hey where have you guys that have done the e-fan mod inserted the temp sensor? I have the thread in style and not sure where I should put it? It is a 1/2 inch metric threaded unit.
Old Apr 1, 2012 | 01:09 AM
gdstock's Avatar
gdstock
If you do not have a threaded port avalable, you can T it into where the temp sensor for the PCM is. But double check the threads. I beleive they are standard pipe threads on these.
Old Apr 1, 2012 | 11:01 AM
redneck_ram's Avatar
redneck_ram
go on ebay and get on of those i linked you to. its a radiator hose adapter. our trucks use a 1 1/2" hose, or 38mm. they have em in all different thread sizes. i have a thread-in style sensor too, and thats the route i went. going to install my fans next weekend. i also have a custom shroud, made specifically for the 2nd gen rams, and 2 16" ff dynamics fans. cant wait to install them!
Old Apr 1, 2012 | 01:08 PM
Hahns5.2's Avatar
Hahns5.2
Using some 1/2" NPT fitting available at any hardware store you can tee into the heater hose...
Old Apr 1, 2012 | 05:53 PM
Silver Bastard
Thats what I was thinking but does the heater circulate all the time or only when the heater is on???
Old Apr 1, 2012 | 06:11 PM
crazzywolfie's Avatar
crazzywolfie
the heater hoses should circulate all the time or you would never get heat until the engine is nice and hot.
Old Apr 1, 2012 | 07:20 PM
Some vehicles have a valve on the heater lines, such that unless you have the temp **** turned to heat, it blocks flow thru the heater core. GM did that on a fair few vehicles, Dodge didn't do so on our trucks.
Old Apr 1, 2012 | 07:55 PM
Silver Bastard
So it does flow all the time?
Old Apr 1, 2012 | 07:59 PM
redneck_ram
for an e-fan setup youre gonna want the sensor as close to the top rads. hose as possible. anywhere in the upper rad. hose will be fine, al long as its a nice straight length.
it wouldnt be wise to have it in a heater hose, just my .02
Old Apr 1, 2012 | 08:01 PM
Hahns5.2's Avatar
Hahns5.2
The heater hose works just fine.
