seals/spacer behind axel??? w/pic
Once installed, there shouldn't be ANY lateral play in the axle. The outer stub should hold everything in place. If there is movement there, something is definitely wrong. If the u-joint pivot point, and the balljoint pivot point, are not DIRECTLY in line, yeah, things are gonna bust.
Something else to check...... is make sure the passenger side inner axle isn't seized up in the tube...... if that were the case, as soon as you put it in 4wd, it would be trying to spin the drivers side twice as fast...... and that will also bust stuff up right quick.
Then that would mean the diff is locked up,no? The tube is way bigger than the intermediate shaft, so I doubt that would happen. Even if the bearing/bushing for the shaft is bad,(or the bushing that goes into the end of it, to align it with the outer shaft is not there) all it will do is cause problems with engagement. Which btw,also seems to be a problem. A Posi-Lok cable only eliminates the vacuum part of the system.
Here's a pic of bearings/bushings. The large one goes in the tube at the left side of the CAD(looking thru the CAD hole) . And the small one goes in the end of the outer shaft to align it with the pin sticking out of the intermediate shaft.
Note, the large one replaces a brass needle bearing. I like the the larger composite one,as it has more surface area to ride on the shaft, if the shaft is worn from the needle bearing. And it is composite material, not plastic.
Dealer part numbers,
5252 686 1 BUSHING, Intermediate Shaft
4137 740 1 BUSHING, Intermediate Shaft5252 686 1 BUSHING, Intermediate Shaft
Or http://quad4x4.com/Dodge1500Dana44front1994-2001.html
Or http://quad4x4.com/ . You might be interested in that site anyway.
