Transmission Filter?
Old Apr 3, 2012 | 08:06 PM
Jesse Keisling's Avatar
Jesse Keisling
Default Transmission Filter?
So I went and got all the goodies to change the tranny fluid/filter in my 1998 ram 1500 5.9, I get my filter out, go to put the new one in and turns out it only has holes for 2 of the 3 screws I pulled out . . .
Thing is the EXACT same size though but with a metal exoskeleton. . . just curious if its the wrong filter or if I'm supposed to use it with 2 screws?
Old Apr 3, 2012 | 08:11 PM
Matt Nickerson's Avatar
Matt Nickerson
I'm not sure about your specific situation but first thing I'd do is match the part number on the box with the part number it says online for you're exact year/engine/transmission.
Old Apr 3, 2012 | 08:22 PM
Jesse Keisling
This is the part. . . where the 3rd bolt was on the other filter there is an indentation in this one.
http://www.equipmax.net/baldwin/cgi_...empartid=96033
Old Apr 3, 2012 | 09:15 PM
Matt Nickerson
Is you're tranny an RE?
Judging from a few pics of 1998 RE vs RH tranny filters, the RH has three bolt holes and the RE has two...edit: although on napa's site every tranny has the same filter w/ 2 holes, So idk.
My best guess is you have the wrong filter. Verify what tranny you have and specify whether it's an RE or RH and if it's a 44, 46, 47, etc. when you buy one.
IDK hopefully someone else who's done it can help you out
Old Apr 3, 2012 | 10:17 PM
He should have a 46RE in his truck.
Old Apr 3, 2012 | 10:32 PM
Matt Nickerson
Well if the part#s match and the bolts fit in and the filter fits on nice...I'd just throw it on.
Old Apr 3, 2012 | 10:37 PM
moss500berg's Avatar
moss500berg
I did my filter a lil while ago, 46RE, three holes in the filter
Old Apr 3, 2012 | 10:43 PM
Wonder if it varies by brand of filter? I would be REAL hesitant to install a filter that didn't take all the same fasteners as the original.
Old Apr 3, 2012 | 11:13 PM
Silver Bastard's Avatar
Silver Bastard
Mine is a 2002 RE and it has 2 bolt holes. Maybe your trans was swapped for a newer unit at some point?
Old Apr 3, 2012 | 11:38 PM
johnnyjaws98's Avatar
johnnyjaws98
i had the same problem but if you look theres a dent IN YOUR FILTER FOR THE BOLT put the bolt in first then the filter. on mine the filter was to deep and wouldnt seat with the pan i returned it and flushed the old filter with gas to clean it out and replaced it
