tranny issue
Old Apr 7, 2012 | 09:48 PM
loneriderty's Avatar
loneriderty
Default tranny issue
ok so i have a 1996 ram 1500 with 5.2 and 46RH trans. 2wd. so the truck hasnt really slipped. but last night comming home after bogging with some friend my tranny shifted funny so today i did a band adjustment and one done it i test drove it. well i was going up a hill. and it made a whinninng sound and started smoking. but i didn't run it i losened the band out some and it quit. but now when i put it into manual 1st gear it won't move and it still won't shift right when passing. any ideas. i'm sure the tranny quit don't know weather it had a tranny put in before me or not. it has 250,000 miles too
sorry for the long paragraph.
Old Apr 7, 2012 | 10:10 PM
JackJ's Avatar
JackJ
*never mind mis-read the post
Old Apr 7, 2012 | 10:15 PM
loneriderty
it might have the 46RE but in my haynes manual it said it's a 46 RH and yes back it off just like it said but i don't feel like i did right cause my torqe wrench was acting funny? didn't ever click
Old Apr 7, 2012 | 11:10 PM
volaredon's Avatar
volaredon
what was your tq wrench rated at; when in that low of a tq range DO NOT use a ft lb model and try and convert!
Old Apr 7, 2012 | 11:41 PM
loneriderty
10 -200 in lb. was rated torque
Old Apr 8, 2012 | 10:56 AM
Your 96 should have the RE....... No manual low indicates a band problem...... What procedure did you use to adjust them? (and I think the rear band, the one 'probably' giving you grief, the adjuster is IN the pan.....)
Old Apr 8, 2012 | 12:16 PM
PapaG's Avatar
PapaG
Actually I think the changeover from the 46RH to 46RE was a mid year change. Not for sure but during my hunt for a used trans I found several 96s that had the RH in it. I don't think I have seen anything about the RH version in the service manual either......
Old Apr 8, 2012 | 12:18 PM
96 was the changeover year from OBDI to OBDII...... A 96 with an RH would be an aberration...
Old Apr 8, 2012 | 12:19 PM
PapaG's Avatar
PapaG
Can't edit on my phone so had to post again. To the OP, if you crawl under your truck and look at the plug situated behind the shift lever. If its a white 3 wire plug its an RH and if it has a black 8 wire plug its an RE.
Old Apr 8, 2012 | 12:20 PM
There's a good test. And don't have to pull anything apart to look.
