wheel bearing help
Old Apr 8, 2012 | 08:22 PM
dhvaughan's Avatar
dhvaughan
do you have stock wheels or other?
and do you have any wheel spacers ?
on autozone's web site they have 2 bearings listed. timken's for about 177 and duralast for 137. i think you get what you pay for - but - the cheap ones should last at least 1-2 years, not 5 minutes.
if they weren't such a pita to change, i'd say just keep replacing them under warranty until you get a good one. but since they are a pita, i'd put in a timken, skf, or national.
heyyou is correct, torque is 185ish on 4wd, less on 2wd.
Old Apr 8, 2012 | 08:25 PM
TC3EMTB's Avatar
TC3EMTB
I torqued it to 200 this time. Last time was 150. The range I found online was 140-150.
The back seals went out on the last one...grease was everywhere.
Old Apr 8, 2012 | 08:30 PM
JackJ's Avatar
JackJ
I had the exact same issue with the Duralast bearing this week, it last about a day and when I pulled it off I had about 2 inches of play up and down with it and the back of it blew out. I replaced it with the next one up and have yet to drive it to see if it happens again.
Old Apr 8, 2012 | 08:33 PM
TC3EMTB's Avatar
TC3EMTB
Oh and stock wheels 285/75/16 bfgoodrich all terrains
No spacers
Everything on truck is stock.
3 inch body lift, 99 ram front end suspension, 94 ram steering
Old Apr 8, 2012 | 08:37 PM
TC3EMTB's Avatar
TC3EMTB
If this one blows I'm getting new 2.5 ton axles and turning it into a bog truck. It's irritating the hell outta me.
Old Apr 8, 2012 | 08:54 PM
95 manual says 175 ft/lbs on the axle nut.
Old Apr 8, 2012 | 08:56 PM
TC3EMTB's Avatar
TC3EMTB
Will the extra hurt it. Not that it matters with the warranty. I mean it only takes an hour to change em.
Old Apr 8, 2012 | 08:57 PM
Looking at how they are designed, nope. Shouldn't be a problem.
Old Apr 8, 2012 | 09:03 PM
TC3EMTB's Avatar
TC3EMTB
Awesome. I had to torque it more cause one of the bolt ridges was covering the hole.
