Overheating.
Old May 10, 2012 | 11:23 AM
  #31
Augiedoggy's Avatar
Augiedoggy
Originally Posted by etdavenport
I just put the 195 stat back in and replaced the temp sensor. [one on right with 2 wires] now my gauge reads just over half way when driving [210]. it runs consistent but its running hot. And sure enough, 20 minutes on the hill was all it took to get really hot. I am looking for the OEM fan clutch and blade now [dealer wants almost $300] at a parts yard. I do not think even that is going to do it though. I checked the radiator hoses a while back and the inlet was about 17 degrees hotter than the outlet,
Are you sure its not just your gauge thats off? a temp gun or good code reader with show what the temps really are... my gauge say 200 with the new 195 stat (had a 180 but everyone said they were bad for mpg since the pcm is looking to reach 195 before leaning out fuel...) if your cruising the rad should cool without really needing much help from the fan...
BTW if you went from 34" to 37" tire diameter this changed your gearing and increased the load on your engine and transmission which will cause everything to work harder and get hotter as well as less power and mpg....that 3" makes a big difference... 4.88 gears are the closer factory match for 37-38 range... especially with the added weight. not that 4.56 wont do the job.... just not as well..and power and mpg results will decrease..
Old May 10, 2012 | 11:32 AM
  #32
Gary-L's Avatar
Gary-L
Veteran: Navy
He stated in his original post that coolant spews out of the overflow. When that happens, there's an issue with running hot.
I have done some research on the site but have not seen anything that fits my problem.
1st: Guy before me swapped out the mechanical fan for 2 giant electric ones. they come on when they should and dealer swears they should work better than the stock fan.
2nd: I have replaced the T-stat with a 180 stat. [twice] just to make sure, Radiator is new
3rd: truck does not over heat under normal operating conditions unless I rev the engine high for a short while passing etc.
OVERHEATS WHEN: Problem occurs most when in 4x4 or 4 low and climbing hills etc. Anytime I am in 4x4 putting more than normal strain on the engine. The temps just rise and rise etc until the coolant overflow fills and then it just spits it out on the ground from the overflow.
This is where I am confused. From the look of the overflow, its meant to do that. there is no hose attachment etc to recirculate the coolant when the PSI changes. its just a spout that dumps on the ground?!?! Is this really normal?
Tranny and Transfer are normal temps, both rebuilt within the last year or so professionally.
Water Pump? [how do i test and what do i look for?] any suggestions are appreciated. [I jsut did the plenum a while back too and ignored the water pump like an idiot....]
I still think it's a very, very minor head gasket leak.
Old May 10, 2012 | 11:53 AM
  #33
A difference of only 17 degrees between inlet, and outlet? Erm..... is this a new radiator? Something is seriously wrong there if it is.
Old May 10, 2012 | 12:02 PM
  #34
Gary-L's Avatar
Gary-L
Veteran: Navy
I missed that. I'm now thinking if the radiator isn't clogged that either the water pump is pushing the coolant too fast or else it's the wrong radiator.
Old May 10, 2012 | 03:06 PM
  #35
Augiedoggy's Avatar
Augiedoggy
uh yeah and then he stated that he replaced the thermostat and it stays constant around 210 on his gauge.... which isnt too much higher than norm so a inaccurate guage and an original faulty stat could also be part of the issue..
I was thinking something would have to be up with the pump or flow through rad as well
Old May 10, 2012 | 03:18 PM
  #36
Gary-L's Avatar
Gary-L
Veteran: Navy
A 180º stat WILL NOT MAKE A TRUCK RUN COOLER!!!!!!!!!!!!!
Old May 10, 2012 | 03:22 PM
  #37
Augiedoggy's Avatar
Augiedoggy
? why do you keep saying that? Who even brought that up? a faulty one that doesnt open correctly can make a truck overheat!
And your plain wrong,
I just changed out my 180 stat with a 195 one and my engine water temp went from maxing out at 189 when fully warmed up to maxing out at 197 now so.....yes it changes the maxumium operating temp of the engine t before circulating coolant it to cool things down and effectively makes things cooler...
the thermostat is a switch.to turn the cooling system on and off.. Put a lower operating one in and you effectively change the operating temp just like a thermostat would change and lower the temp in a room when turned down and set to activate at a lower temp.... how do you thing they work?
someone else please chime in here!
Old May 10, 2012 | 05:31 PM
  #38
gdstock's Avatar
gdstock
A 180 stat (functioning properly) will open sooner than 195, but if there is a cooling issue like excess flow or inadequate flow (clogged passages in block or rad) the rating of tsat will be inconsequential.
Head, blockage, air trapped in system.....something is causing the system not to provide proper cooling to the engine...
Old May 10, 2012 | 06:14 PM
  #39
charlie1935's Avatar
charlie1935
If I'm not mistaken the thermostat rating is the temperature that they start to open, not fully open.
Old May 10, 2012 | 06:17 PM
  #40
johnnyjaws98's Avatar
johnnyjaws98
are you getting a girggling sound in your heater core
