Wipers sort of delay...
Old Apr 12, 2012 | 12:39 PM
InfO's Avatar
InfO
Default Wipers sort of delay...
Howdy All,
First, I'll start with I've searched and read a lot of messages about the wipers not working at all in the delay setting, only working in high and low. And yes, first thing I did check was the fuse that makes the dinging when the door is open (and is thus tied into CTM I believe?).
The particulars of my problem are a little different, so I thought I'd put them up so that A) if anyone comes across anything similiar, hopefully by the end there is a quick solution and B) to see if anyone has a suggestion that will negate some tearing apart (I'm not at home, not with my own tools, just on a base where I have to borrow).
My wipers work in high, low, AND delay... sort of. I can turn the selector to any delay setting and they start... and then randomly stop somewhere on the window. They only go again if I notch the wiper switch up or down one notch. Then they will wipe again, usually getting a full 'swoosh' of the windshield before stopping somewhere else. This results in a bit of play in order to get them to park back at the bottom of the window. As I said, they run fine on high and low like everyone elses. I'm curious, is the thought this might have more to do with the switch or is it likely the CTM? Like I said, it's a bit different from others in that they usually have NO delay, or their delay only works at one speed no matter what is selected.
Hopefully I can solve this so I can jump onto that damn driver side door lock issue (it doesn't rise or lower... just sort of... bumps in place).
Inf O.
Old Apr 12, 2012 | 12:47 PM
Probably need a new wiper motor, that's where the supposed "smart part" is rumored to be.
Old Apr 12, 2012 | 02:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the multifunction switch too. Pull the steering column covers and check all wires and plugs. Remove the cowl and check the wires and plugs, and ground there too(at the wiper motor). If it all looks good, I'd say motor like HeyYou stated.
Old Apr 12, 2012 | 02:32 PM
InfO's Avatar
InfO
Thanks zman and HeyYou! Long time no talk!
I'll pull the steering column covers and the cowl and check all wires/plugs tomorrow. I'll post up what I find out. I downloaded the service manual, so should be able to tackle it.
Thanks,
Inf O.
Old Apr 12, 2012 | 02:34 PM
dlyter09's Avatar
dlyter09
I had the same issue and mine ended up being a wire pulled out of the connection behind the multifunction switch.. I had a thread about it here somewhere
Old Apr 12, 2012 | 02:51 PM
If you have tilt wheel, that is definitely the first place to look.
Old Apr 12, 2012 | 02:54 PM
mibzzer15's Avatar
mibzzer15
I had a friend of mine in auto shop that had the EXACT same problem as you do, and by exact i mean EXACTLY the same problem.
He replaced the wiper motor and it was fixed.
Old Apr 12, 2012 | 03:20 PM
zman17's Avatar
zman17
That's too easy, and cost money. We are just trying to eliminate other free possibles first.
Old Apr 12, 2012 | 07:29 PM
dhvaughan's Avatar
dhvaughan
failure of the wiper system to "park" the wipers at the bottom of the cycle is a failure of the park circuit. this can be either -
a bad park circuit in the motor. replace the motor.
or
an open wire for the park circuit, which should have 12v anytime the ignition switch is on. repair the circuit. you can duplicate this by turning off the ignition when the wipers are on, and you'll see the wipers stop dead where they're at.
so - test the park circuit wire at the motor. it might be blue?. if its good, replace the motor.
more info.
http://www.lotuselan.net/forums/elan...or-t22172.html
Old Apr 12, 2012 | 07:32 PM
mibzzer15's Avatar
mibzzer15
eh you got a point there lol! Just giving my 2 cents anyways haha
