Starting issue- hopefully can be solved
Old Apr 14, 2012 | 07:23 PM
gertie240's Avatar
gertie240
CPS or the coil, when the coil gets hot it will start to act up.
Old Apr 14, 2012 | 09:41 PM
Wombat Ranger's Avatar
Wombat Ranger
My truck has a brand new crank sensor and coil, and still exhibits the symptoms.
Old Apr 15, 2012 | 09:04 PM
Uncle Bannerman's Avatar
Uncle Bannerman
new fuel pump this weekend, let's see if that fixes the problem. Its a 95 so the auto parts stores tell me that they can't scan it. I tried to use the key on and off thing to get it to flash a code but no dice. If this doesn't work, I'll try to open up the computer.
Old Apr 15, 2012 | 09:12 PM
Wombat Ranger
Keep us (me...) updated!
Old Apr 15, 2012 | 10:07 PM
Not sure about the dodges... but, on the GM OBDI systems, if you short pins a and b on the ALDL, and turn the ignition on, (but, don't start the engine.) it should flash codes at you.
Old Apr 16, 2012 | 09:09 AM
4angrybadgers's Avatar
4angrybadgers
Uncle Bannerman, your starting issue sounds just like mine. I'll keep an eye on the thread in case you find the solution.
For reference, I have a 2002 2500, 2wd with the 5.9L gas engine, 142k miles or so. I did the spark plugs in the last few thousand miles, and the distributor cap+rotor along with my plenum repair + timing chain/gears fix a few months ago. I haven't touched the fuel system because the problem isn't worth the time or money for me right now - it always starts eventually.
edit: Oh, and I've never seen an error code besides a P1486 (probably a pinched EVAP hose), but I had the starting issue before that error.
Old Apr 16, 2012 | 09:42 AM
Uncle Bannerman
For the obd1 dodge, you turn the key on and off three times and the check engine flashes a certain number of times, corresponding to the code in the computer. Tried that and nothing. Got the day off so going to take the truck on a road test. For those who said they have the same starting problems as I do, how long has it been going on?
Old Apr 16, 2012 | 10:42 AM
4angrybadgers
I've had my truck since July 2011, but I think my starting issues didn't show up until winter. There were a few multi-week periods where the issue would disappear. That said, I haven't found any correlation between the issue and the weather.
Old Apr 16, 2012 | 05:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is the bulb good? If you are doing it correctly, it should flash. At least for a 55 code.
Old Apr 18, 2012 | 04:29 PM
Uncle Bannerman
Finally got the computer to flash a code at me and I might have a lead! It flashed 54, which the manual says is a camshaft position sensor. I know that's supposed to be under the distributor cap, but when I called the auto parts store, they told me that they don't sell them for my truck (1995). Is it part of the distributor and cannot be purchased separately or a dealer part? Or does it exist at all? Any thoughts would be appreciated!
