No 1st gear when in 'D'.
Old Apr 19, 2012 | 09:09 AM
They are both on the valve body, and easily accessed with the filter out of the way.
Old Apr 19, 2012 | 05:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Sooper
If you don't mind me asking, what are your thoughts on why the pressure sender and solenoid wouldn't be the issue. I'll know more when I perform the test.
By the way, where is the pressure sender located? I assume the governor is accessed by removing the pan...is that where the sender is as well?
Thanks.
Because the gov solenoid and pressure switch 9 times out of 10 cause slow or no shift from 2nd to 3rd. I'm no tranny expert and I was just going with the odds. You have to remove the pan to replace them anyway. And after doing so and seeing whats in it the pan, will tell a better story. Just curious, but how did it shift before he had the tranny service done?
Old Apr 19, 2012 | 05:57 PM
Sooper's Avatar
Sooper
From what he has told me the problem has been there for a long time but because it still worked fine 2nd gear and up he never bothered. He just put up with the slow sluggish starts. He's religious about servicing his cars and trucks though so every 3000 miles it was in for oil change service and scheduled transmission services.
Aside from the transmission not going into 1st gear at a stop when in 'D' it shifts just fine in and out of every other gear.
Old Apr 19, 2012 | 06:12 PM
zman17's Avatar
zman17
I would suggest trying the key trick for the hell of it to see what comes up. But, for some unknown reason it doesn't work on a 98(I had one). You simply have to take it to a tranny shop and have them check the pressures with gauges or a scanner. Or replace the solenoid and adjust the bands, and hope for the best. Sorry, but thats the best of my knowledge as far as transmissions go.
Old Apr 19, 2012 | 07:27 PM
drewactual's Avatar
drewactual
For what its worth, and no disrespect for the man of z, but my issue sometime back was the same, and it was either the speed sensor or the solinoid.. both were clogged up.
Old Apr 19, 2012 | 08:08 PM
Sooper's Avatar
Sooper
I plan on replacing both either way. Can't hurt.
Did anyone dig up the BW pressure sender part number? I didn't find it yet in my search.
Old Apr 19, 2012 | 09:48 PM
Mfg Part # : 50185
Old Apr 19, 2012 | 09:55 PM
Sooper's Avatar
Sooper
Mfg Part # : 50185
Thank you sir, that's the part number for the solenoid. It was posted a little bit earlier.
The one I still needed was the part number for the pressure sender.
Old Apr 19, 2012 | 10:00 PM
Here's both for 99.00 bucks.
Old Apr 19, 2012 | 10:11 PM
Sooper's Avatar
Sooper
That's perfect, thanks. I'll get those ordered and if successful I'll be sure to report back. You've been a huge help, same to everyone else, thanks so much.
