timing chain help
Old Apr 17, 2012 | 06:14 PM
Ham Bone's Avatar
Ham Bone
I just took the old ones off and put the new ones on. Mine was keyed so I dont see how dots would make a difference
Old Apr 17, 2012 | 06:17 PM
The dots are to make it easy when you are assembling an engine from scratch. If the replacement is just because the old one is all stretched out..... lining up the dots keeps it from going in a tooth or so off. The morse syle chins stretch a LOT.
Old Apr 17, 2012 | 06:32 PM
Ham Bone's Avatar
Ham Bone
Whats a morse chain? The stock style?
Old Apr 17, 2012 | 06:42 PM
johnnyjaws98's Avatar
johnnyjaws98
when i took it apart i lined up the 2 dots took off the chain and gears put the new ones on that should of been it right . but now it wont idle and has no power and knocks on orther site says too line up marks then turn one revelosion then put in dis i cant belive this ive done dozens of chains before and never had a problem none on a dodge truck ran great before this
Old Apr 17, 2012 | 07:47 PM
merc225hp's Avatar
merc225hp
Did you reset the pcm after you installed the new chain, if not discon the neg side of the batt let it sit for a few then recon and start the truck, the pcm my take a little time to relearn. If you have removed the dizzy or turned it you will need to have your fuel sync reset using a scanner.
Old Apr 17, 2012 | 08:31 PM
johnnyjaws98
bought it to the dealer and they sinc it still ran bad they think timing is off took it home 109.00 dollars later took it apart checked timing# 1 valve cover put it to tdc was dot to dot someone said has to be on compression stroke but when on it dot on cam is up top im lost should i try it on # 6 clyender 6 and 1 are both up to the top at the same time
Old Apr 17, 2012 | 08:44 PM
PapaG's Avatar
PapaG
I know when I changed my timing chain that when I put the new gears on the marks did not line up. The cam mark and crank mark were both at the 12 oclock position. It kinda threw me off but I knew it was right because with the keyways theres only one way for it to go on. With the timing marks lined up my rotor was pointing at #6 not #1.
Old Apr 17, 2012 | 09:00 PM
johnnyjaws98
mine to i did everythingright cant fig it out
Old Apr 17, 2012 | 09:34 PM
aim4squirrels's Avatar
aim4squirrels
Your engine is a four stroke engine, not two. There will always be two pistons near TDC. One is on the compression stroke, one on the exhaust stroke.
With the top cam gear dot in the 6 o'clock position, and the bottom crank gear dot in the 12 o'clock position, the #6 (not the #1) cylinder is about to fire.
Rotate the dots so both are at 12 o'clock. Now, take off the distributor cap. If the rotor firing point is even with the line on the plastic plate just below it, your timing is correct if it's 180° off, you hosed the chain install and got it backward.
If it's anything other than spot on or 180° off, you really hosed it and might need to degree the cam to fix it.
Old Apr 17, 2012 | 11:23 PM
johnnyjaws98
i didnt know there was a lin on the plastic plate ill check it out thanks
