Tranny issues, need help
Old Apr 22, 2012 | 11:55 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm afraid in this case it most likely is rebuild time. From what I've read here and there, 1763 is not good when it keeps popping up after replacing the solenoid. Did you thoroughly check the harness inside the transmission when you had the pan off?
Old Apr 22, 2012 | 12:35 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by georgiahemi
Okay guys, even more stumped now. This weekend, my brother and I checked the hose and check valve and it worked perfectly. The ball moved easily. Then we checked the O2 sensors like bjr1a had suggested. Everything was fine there. Then we drained the fluid and dropped the pan. We checked the sensors and all the connections. Everything looked good. Put the pan back in and checked a lot of wiring. There was a loose connection on the connector for a harness going into the top of the trans. We cleaned it all up and connected it back, test drove it, and a half hour later, same problem. I am at a loss here guys. Can't really afford to take to trans shop that I know will just say rebuild time.
Thats because it IS rebuild time.... not having the funds and ignoring the obvious does not change the problem... Like I said before if it was the check valve you would have seen the od light come on when it overheated...
I know, I was there in december... I had to charge half my rebuild..
Old Apr 22, 2012 | 04:18 PM
chevy62's Avatar
chevy62
I was helping georgiahemi try to diagnose this. If I saw trash in the solenoid screens and in the pan I would agree that it is rebuild time. But since everything is so clean, I would have to think it is either a wiring issue or a high pressure. Unfortunately, I dont have access to a good scanner to check running parameters or gauges to test pressure.
Does anyone know the voltage range that the GPS operates at? I know when it gets to 4.9 ish it is out of range, or too close to 5 volts and sets the code. Also, the harness that goes from the trans to the PCM, is that a complete engine harness?
Old Apr 22, 2012 | 04:33 PM
zman17's Avatar
zman17
Download the 2001 fsm from the FAQ/DIY section so you can trace the wires. And check the 8 pin main plug on the tranny again.
Old Apr 22, 2012 | 04:35 PM
Looks like the Red wire is the power feed for ALL the trans stuff. Should be 12 volts going in. Governor pressure input to PCM is in connector 2, cavity 29, Light Green/White wire. Check voltage at that wire, see what ya get. It's possible that wire is shorted somewhere along the way, giving false readings to the PCM.
Old Apr 22, 2012 | 04:56 PM
Augiedoggy's Avatar
Augiedoggy
if he recently replaced the solenoid like he said he did he would have cleaned the pan and doughnut magnet too right? or was everything clean the first time it was opened? if so I'd think someone else was in there because these things usually have a lot of metal stuck to that magnet during normal maintenance time.
because if not its very likely the valvebody passages could be partially plugged causing the pressure to be out of whack at the soleniod....
thats what happened to mine... I tried replacing the soleniod and still had the error along with like three others..
Old Apr 22, 2012 | 05:02 PM
chevy62's Avatar
chevy62
Thanks for the tips guys. I looked at the 8 pin plug, it was definately better than that pic zman posted!! I havent pinned out any wires yet, but that is the next step. It sounds like the GPS input could be shorting to 12 volt causing this whole issue. If we can ever get this thing fixed, we will do a write up on exactly what we did. Thank you all for helping!!
Old Apr 22, 2012 | 05:07 PM
The write up would be GREATLY appreciated.
Old Apr 22, 2012 | 06:09 PM
chevy62's Avatar
chevy62
After reading the service manual, I think I need to test governor pressue first to verify if it is a pressure issue or electrical. Looks like all I need to do the test is hook up a pressure gauge to the governor test port. I have an oil pressure gauge that I could rig up and with enough hose, I could have the gauge in the truck to monitor. I am thinking if it is within specs at idle and at speed, we can be sure it is in the wiring.
Old Apr 22, 2012 | 06:14 PM
That should work just fine. A list of any adapters needed would be good to have.
