Better 1/4 mile time
Old Apr 19, 2012 | 02:55 PM
Wombat Ranger's Avatar
Wombat Ranger
It was optional. But seriously, stop looking at the trak-lok.
Old Apr 19, 2012 | 03:26 PM
CappinHoff's Avatar
CappinHoff
Just putting on gears and an LSD are't going to increase your times by very much. Like someone said, it's a heavy truck not supposed to go fast. If you want to go fast get a car. If you want your truck to go fast, you're gonna spend some $$$.
Old Apr 19, 2012 | 06:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
http://www.rm-indy.com/
Old Apr 19, 2012 | 07:42 PM
MoparMadnessMan's Avatar
MoparMadnessMan
I'm not trying to turn it into a 9 second truck! Just make it a little more fun to drive and take to the strip on the weekends and the only thing that won't be minor as far as aftermarket parts are the gears heads and intake manifold. All the rest will be bolt ons unroll I decide weather or not to rip all of the wiring out and go with an old school carb and tranny setup or not
Old Apr 19, 2012 | 07:56 PM
Adobedude's Avatar
Adobedude
Ditch the TB spacer. Worthless
Not going to find a spool for a 9.25, and I doubt you are spinning much off the line so no need for a locker, however see below.
Pulling weight off is easy.
No AC
No Heat
No EVAP
No Radio
No carpet
No headliner
One seat
No door panels
No fender liners
You can ditch the Power sucking 46RE for a 727, but no OD.
For the motor...
M1 4bbl (2bbl M1s suck for a drag motor)
58 TB
Eddy Heads
Cam-rockers-springs-push rods-timing chain...
Headers: Done
Delete the cats: Done
Free flowing exhaust
All this can make a 360 run.
Then you will need gears and a Locker so do that too.
Other stuff...Start the truck, pull something out, if it keeps running great, if it quits put it back in...
Old Apr 19, 2012 | 08:31 PM
MoparMadnessMan
Haha it already has no spare tire/ tools or any ac related parts and my problem with some of the performance parts is I've been cursed with OBD1...great philosophy though!
Old Apr 19, 2012 | 09:07 PM
Wombat Ranger
This may help you marginally improve your ET's. I hope it helps. Please post a DIY of the install.
Old Apr 19, 2012 | 09:38 PM
Oooooooo.... that'd be funnnnnnn..... tad pricey though, even on sale....
Old Apr 19, 2012 | 09:47 PM
Ham Bone's Avatar
Ham Bone
I wonder why there are no customer reviews.
Old Apr 19, 2012 | 10:35 PM
Arde's Avatar
Arde
Really, it just comes down to power/weight ratio. You'll get the same results lowering the weight as you will by building the engine, and it's a lot cheaper.
Then build the engine.
Get it to hook up.
You're gonna spend the rest of your life thinking...I need just a little more power.
Hot rodding stays in your blood.
