build my own relay box
Old Apr 24, 2012 | 07:04 PM
Motorizer's Avatar
Motorizer
Default build my own relay box
I'm wanting to build my own relay box with 5 or 6 relays for all of my offroad lights.
very similiar to this
http://www.youtube.com/watch?v=HmoaKsfwug4
I'm wondering if anybody has a wiring diagram for such thing. And if I can run just one ground and positive wires between 5 or 6 relays then ground the 1 wire and run the the positive wire to a inline fuse and to the battery. Maybe someone could help make a wire diagram for me on how to correctly do this.
thank you in advance for any and all input
Old Apr 24, 2012 | 07:17 PM
Do you want one switch to control ALL the relays? Or do you want them individually switched?
Old Apr 24, 2012 | 10:57 PM
Motorizer's Avatar
Motorizer
individually switched. I want to just have less wires going every where and less wires hooked up to the battery.
Old Apr 25, 2012 | 09:08 AM
Gonna have to have a FAT power feed wire then...... How many lights do you wanna run, and what wattage are they?
Old Apr 25, 2012 | 09:56 AM
grox's Avatar
grox
You can have all of the power and ground for the relays in parallel, but you will want to fuse each relay individually, or else you will need a fuse large enough for all 5 of your relays and whatever wires you choose to use for each one, when you need to have a small enough fuse to protect the weakest link in your wiring (to prevent fire).
Old Apr 25, 2012 | 10:26 AM
crazzywolfie's Avatar
crazzywolfie
almost sounds like you need a 2nd PDC maybe out of an older dodge vehicle.
this one came out of a 94 Plymouth voyager.
Old Apr 25, 2012 | 04:32 PM
Motorizer's Avatar
Motorizer
13 in total i have 4 up in front of the truck 5 up top on the headache rack facing forward plus 2 facing backwards then two on my back bumper so 13. 9 of the lights are 130watt Kc daylighters so 130watts x 9 = 1170 watts then the other 4 are 100 watts =400 watts
so 1170 watts + 400 watts = 1570 total watts
at most i only ever use is two lights since I still have the stock alternator. I will be doing a duel battery setup this summer along with my winch. just want the install to be as clean as possible I don't want a ton of wiring all over the engine bay.
@grox thats about what I want to do just need help with a wiring diagram for this.
@crazzywolfie would that be easier?
Old Apr 25, 2012 | 05:46 PM
peshewa's Avatar
peshewa
You will do well to look for a home made dual fan electric conversion sire set up then simply use it for lights instead. I posted one a while back, search by my name & go back at least 6 months. It is very detailed. As for the box, I used an outlet box made for 3 110 volt wall switches from home depot. I made a waterproof lid from another part of a similar box then made a silicone seal for it that is removable (ask me how) then used common bees wax around the wires going into the box. It stays bone dry inside. I can not say it looks super cool, but it functions all the way through a sloppy Iowa winter.
Old Apr 25, 2012 | 07:40 PM
crazzywolfie
now that i know you are running 1570watts of stuff i would have to say no. would most likely have to replace all the wires with heavier wires.
Old Apr 25, 2012 | 07:44 PM
gdstock's Avatar
gdstock
...or put a Honda generator in the bed.....That's a lot of load on your alternator.
