fuel pump ???? 100k dodge syndrom??
Old Apr 25, 2012 | 08:43 PM
Holly Magnum's Avatar
Holly Magnum
Default fuel pump ???? 100k dodge syndrom??
i was dring my 1007 ram 1500 360 magnum home from a quick trip to the convence store. its run fine all day but on a turn at 20 mph the engine stoped.i tried to restart it but it fires once then dies and will only crank and not sputter.20 min later it fired once and then only cranked.
Old Apr 25, 2012 | 08:49 PM
See what you are missing, spark, or fuel.... might be a bad crank sensor as well.
and, 1007? did they even HAVE internal combustion engines then???
Old Apr 25, 2012 | 08:52 PM
Holly Magnum
i have spark. im not sure if its the pump, relay or fuse. where is the relay and fuse. and would the pump have given warning. and its a 1997. to distrught to type
Old Apr 25, 2012 | 08:59 PM
Sometimes the pump will go slowly, and you will notice it, other times, it will just stop working altogether, even though you can hear it run.
Do you hear the pump prime when you first turn on the key?
Relay is in the Power Distribution center under the hood, behind the battery. Fuse is there as well. Can try swapping the FP relay with just about any of the other ones in there. (horn works good.)
Old Apr 26, 2012 | 06:05 AM
Holly Magnum
i checked the fus and relay its the pump. thanks for the help
Old Apr 26, 2012 | 10:26 AM
Wombat Ranger's Avatar
Wombat Ranger
Sounds like the crank sensor to me. If I had 2 votes they would both be for that. If it came loose it could do exactly that. It happened to me once.
Old Apr 26, 2012 | 05:51 PM
gdstock's Avatar
gdstock
Slap a gauge on it and check fuel pressure before spendng the money and labor changing the pump. Crank sensor is a good option to check as well.
Old Apr 27, 2012 | 06:34 AM
Uncle Bannerman's Avatar
Uncle Bannerman
This exact thing just happened to me. Crank sensor. Replace the pickup coil on top of the distributor as they are part of a circuit and if you change one, it might not do any good. BTW, crank sensor is a total bear to get to.
Old Apr 27, 2012 | 10:14 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Edit: nevermind. Why do we have two threads going on the same topic?
Old Apr 28, 2012 | 12:14 AM
Holly Magnum
is the crank sensor related to spak?
