grinding noise when driving
Old Apr 27, 2012 | 03:35 AM
big show's Avatar
big show
Unhappy grinding noise when driving
Hello wondering if anyone can help I have a 01 ram 1500 4x4 quad cab and it's been great tell today! i pulled out of the backed out of the driveway and when i started to drive i herd a grinding noise.it happens in drive and revers the rear diff is full could it be the u-joints or might it be the transfer case as it don't sound like it's in the wheels .any thoughts you have would be great,not sure were to start.thanks for any help
Old Apr 29, 2012 | 10:40 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the 2nd Gen Ram section.
Old Apr 29, 2012 | 11:04 PM
gdstock's Avatar
gdstock
You cannot tell where the sound is coming from? Maybe drive slowly while someone is walking beside the truck can help tell where the sound is coming from.
U joints will click.
Old Apr 29, 2012 | 11:23 PM
dhvaughan's Avatar
dhvaughan
welcome to DF. can you put the rear end up on jack stands. spin the wheels by hand. start it up and try drive and reverse (gently).
Old Apr 30, 2012 | 10:07 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Drain and check the fluid in the transfer case also. Could be you need one of these too.
You'll have to remove the tail shaft to check it. I wouldn't wait too long to check.
http://www.drivetrain.com/parts_cata...ase_saver.html
Old May 2, 2012 | 03:38 AM
big show's Avatar
big show
sounds like t case .it's there in drive and reverse in 2 or 4x4 .i can hear it if i put 4x4 shifter in N and put truck in drive or reverse
Old Jul 1, 2012 | 03:22 AM
DJeXeCute's Avatar
DJeXeCute
You know I was having the same problem the other day. I went to my buddys grad party out in streetsboro ohio and I was doing burnouts on in his street and sliding around turns on dirt and after about 15minutes of beating the hell out of my new 518 tranny I started to hear a grinding noise coming from the back. (I only have 2wd and the stock Dana 35 3.55) I headed off to the nearest Autozone and as I drove it went away before I made there and when I asked the guy what he thought it was he had no clue what it could be. It's been quite but I was swinging around in the dirt today and it slowly started to come back but as soon as I laid off it went quite. Not sure if this is the same problem your having. I'm guessing the axle shaft is heating up in the housing and rubbing but I'm just a backyard self taught mechanic.
Old Jul 1, 2012 | 01:16 PM
zman17's Avatar
zman17
You think maybe a Ram or any brand truck for that matter, is made for doing burnouts and/or donuts? LMAO
Old Jul 1, 2012 | 09:33 PM
gdstock's Avatar
gdstock
And the guy at Autozone didn't know what was wrong with it? Really? LMAO2!
Old Jul 2, 2012 | 05:21 AM
DJeXeCute's Avatar
DJeXeCute
Well do you think it's anything serious or should I just ignore it and wait for something to explode?
