98 Dodge Ram Performance
Old May 7, 2012 | 01:31 PM
  #51
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^Yes, they wake up your engine and they do a really good job if you have had some exhaust work done and have a tune.
However, DO NOT use them if you have a 5.2, the 5.2's have a different piston design that can cause the valves to smack the piston causing some major carnage.
Old May 7, 2012 | 01:36 PM
  #52
Easier than doing a cam swap, lot less work involved.
Old May 7, 2012 | 01:38 PM
  #53
dodge dude94
^Oh, you mean a lot less to screw up?
Old May 7, 2012 | 01:39 PM
  #54
I didn't say that.......
Old May 7, 2012 | 03:14 PM
  #55
Augiedoggy's Avatar
Augiedoggy
This is the first I've read about this? Dont we have plenty of members here with 5.2l and 1.7 RR's?
Old May 7, 2012 | 03:51 PM
  #56
98Ramboy's Avatar
98Ramboy
Well I've got a 5.2 so..do I have to look for different rockers? And by getting these rockers, will I have to upgrade other parts right away? Or can I install them and wait for the next project?
Old May 7, 2012 | 03:56 PM
  #57
I am pretty sure we have folks with the 5.2 that installed these, and didn't have issues..... and no, don't have to do anything else. take off the old ones, put on these, (follow proper procedure...) and drive it.
Old May 7, 2012 | 04:07 PM
  #58
zman17's Avatar
zman17
Retired Moderator - RIP
Yup, my 1.7's I have in my 360 now , used to be on my 318.
Install them properly and go. As HeyYou stated.
Old May 7, 2012 | 04:33 PM
  #59
gdstock's Avatar
gdstock
I just ordered a set last weekend....for a 5.2.....
This is the first I have seen about any issues. Since they do not open the valve farther, and the piston should not be at the top when valve opens...I don't see this being an issue. (But if it is I would like to know now!)
Old May 7, 2012 | 05:33 PM
  #60
Wombat Ranger's Avatar
Wombat Ranger
Actually, in relation to the 5.9, they do open the valve further, due to the stock 5.2 cam having slightly more lift. This might be what DodgeDude was thinking of, but I don't think it causes any sort of interference, since you can swap to a significantly bigger cam in a 5.2 with a stock valvetrain...
5.9 = .410/.410 int/exh
5.2 = .432/.432 int/exh
Either way, the valvesprings are good for .515" of lift, if I recall correctly...
