ECM P/N No good
Old Apr 30, 2012 | 01:01 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by A_POLVADO
Another question for you two I am noticing now that if I reset the pcm or on start up when the engine is cold it pops through the intake and bogs down but clears out after a few minutes Im thinking tps or iac going bad the stumble and pop only occurs on initial throttle under 15-1600 rpm maybe crank sensor. Also the iac sound like a jet engine on first start up it sucks so much air untill it warms up then its fine
Before or after the SCT install? A 14x3 sounds that way, which is why I hate them. LOL Shouldn't be any popping either way. Is the plenum fixed along wit a new cat and o2 sensors?
Old Apr 30, 2012 | 01:22 PM
A_POLVADO's Avatar
A_POLVADO
b4 sct havent received it yet .Yes it has a 14x3 so thats normal the popping and falling on its face I have no clue but the plenum was fixed with o2 sensor and gutted cat for time being.
Old Apr 30, 2012 | 01:32 PM
How old are your O2 sensors?
Old Apr 30, 2012 | 02:10 PM
zman17's Avatar
zman17
How was the plenum fixed? Anyway, you should add the fact to you sig.
Old Apr 30, 2012 | 02:44 PM
A_POLVADO's Avatar
A_POLVADO
4 months on the 02 sensors with a billet plate new bolts and a felpro gasket
Old Apr 30, 2012 | 02:52 PM
A_POLVADO's Avatar
A_POLVADO
Done
