1999 dodge 1500 4x4 differential slopp
Old May 3, 2012 | 07:39 PM
Dave Anderson's Avatar
Dave Anderson
Default 1999 dodge 1500 4x4 differential slopp
I replaced axle bearings, and i still have side to side play. Could this be differential bearings ? if so, is there any thing i need to know before i pull it out and replace them. Any help would be greatly appreciated.
Old May 5, 2012 | 11:24 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/dodge-r...s-section.html
Old May 6, 2012 | 08:06 AM
Where is your slop? Out at the end of the axle?
Old May 6, 2012 | 09:43 AM
zman17's Avatar
zman17
Retired Moderator - RIP
IF, we are talking about the rear, some play is normal. Just depends on how much.
Old May 9, 2012 | 10:39 AM
Dave Anderson
no, the slop is inside the carrier, where the axle rides. could this be the shims or gears. it makes a rattle like bad u-joints when letting off the throttle.
Old May 9, 2012 | 10:45 AM
Dave Anderson
no it is in where the axle rides in the carrier, could it be shims or gears. ? it makes a rattle like a bad u-joint when releasing the throttle and coasting.
Old May 9, 2012 | 05:26 PM
As in, the axle rattles around inside the side gear? If that's the case, I would seriously consider replacing the axles AND the side gears. (although, I think spiders come as a set of 4......)
